456 headlight cover - Ferrari Life
post #1 of 3 Old 01-26-2014, 12:03 PM Thread Starter
Ferrari Life Posts: 14
456 headlight cover
Both my 456 headlights work but the headlight cover on one does
not open. Any suggestions?
NORMAN STORM is offline
post #2 of 3 Old 01-26-2014, 12:55 PM
Ferrari Life Posts: 967
Verify power at the motor connector. If OK, you'll likely need a new headlight motor, as there are no serviceable parts/adjustments possible.. You can try to cycle the motor with the override knob...Sometimes, the internal contacts within the internal motor position switch get a bit oxidized. I recently went through this exercise on a client's 456M.
post #3 of 3 Old 02-19-2014, 01:42 PM
If you can remove the motor you should be able to get it rebuilt at any good electrical shop if you can't get it to work otherwise.
Yukon42 is offline
