456 GT Will Not Start - Help ! - Ferrari Life
post #1 of 3 Old 08-03-2004, 09:44 AM Thread Starter
Ferrari Life Posts: 15,136
My 456 GT will suddenly now not start. The car has an immobilizer which appears to be working properly. However when you turn the key to start the car, it fires up and then dies after about 3-4 seconds, it sounds like the engine is not catching and/or getting fuel. Additionally this morning a clicking noise suddenly appeared and seemed to be coming from behind the tachometer, (whihc may or may not be related). Up till now it was running beautifully. I did check the fuses for the fuel pumps and both are fine. Any suggestions as to what the problem could be ?
Thanks.
post #2 of 3 Old 08-03-2004, 02:43 PM
Ferrari Life Posts: 749
The clicking does sound like a relay tripping in & out, but I've no idea what it may be.
It wouldn't give the "dying after start" symptoms, but I have heard of many immobilisers draining the battery after a time. A low voltage could also lead to relays not holding properly, but once the car fires the alternator should then make up any voltage deficiency if that was the problem. Hmmm (thinks).
ps: You did say CLICKING didn't you (not TICKING! => run away! run away! :green: )
4kids3fish is offline
post #3 of 3 Old 08-08-2004, 05:48 AM Thread Starter
The problem turns out to be pretty serious issue with the camshafts. It will probably take a couple of weeks to fix.
Thanks for the help.
