550-575 torque tube question - Ferrari Life
post #1 of 6 Old 12-01-2013, 01:09 AM Thread Starter
Ferrari Life Posts: 310
Hi all, anybody taken one apart to replace the bearings in a torque tube? It looks similar to a Maserati 4200 Spyder but it's about 3-4 inches shorter, which is what I'm looking for. The 4200 version is not possible to take apart, officially anyway. Rgds///Thomas
C311 is offline
post #2 of 6 Old 12-01-2013, 10:59 AM
A long time ago, yes.
It has long tubular white plastic spacers that keep the drive shaft in place. Tapping the shaft out from one end will get the spacers, shaft and bearing out. I don't recall replacing the bearing itself so there must not have been much to it.
post #3 of 6 Old 12-02-2013, 02:04 AM
550_Maranello's Avatar
Ferrari Life Posts: 1,232
HI Thomas,
please find attached an extract of spare parts catalogue of 575M, i hope that help you, remove the complete connecting tube is medium easy, is necessary disconnect the gearbox and shift back it (or remove) in order to take off the splined shaft, after that you remove bolts from clutch bell and the pipe go down.
To replace the ball bearings I think need special tool, but possible you can made by yourself.
Regards
Fabio
File Type: pdf Spare Parts Catalogue 575M_CONNECTING TUBE.pdf (78.1 KB, 167 views)
Fabio
550_Maranello is offline
post #4 of 6 Old 12-02-2013, 02:50 AM Thread Starter
Thanks for your replies. The procedure looks like the same as for Porsche 944/928. A long threaded rod and some flat bar to push/pull the bearings out. Rgds///Thomas
C311 is offline
post #5 of 6 Old 12-02-2013, 08:43 AM
Ferrari Life Posts: 11,881
Thomas- A 456 owner or fixer recently did one on the other site.
post #6 of 6 Old 12-03-2013, 01:16 AM Thread Starter
Thanks for the info, Terry. Maybe there are pics too.
By the way, my daily driver was sold new by Desert Sun Motors in Alamogordo, NM. I found it in Frankfurt, Germany 9-1/2 years ago with US-Army plates and some front end damage.
C311 is offline
