Timing belt drive pulley bearing replacement - Ferrari Life
post #1 of 1 Old 11-02-2013, 02:14 PM Thread Starter
AkaiAkuma's Avatar
Ferrari Life Posts: 186
456GT of Mr.SHIKAKURA owned Yamagata Prefecture to went to the meeting.
A problem has occurred with a local.
Timing belt drive pulley bearing is damaged.
Bearing of one side was damaged.
It tries to Nukitoro the front cover and bearing-only tool which I produced before, it will not come out if you are stuck.
The shaving the bearings, remove the ball, has been removed.
It does not take the parts bearing the remaining gear was scraped off in all processing plants.
I handed over to the owner at the station.
AkaiAkuma is offline
