Cranking issue - Ferrari Life
post #1 of 6 Old 10-11-2013, 12:34 AM Thread Starter
Jay Kay's Avatar
Ferrari Life Posts: 76
Cranking issue
Hi Everyone
I have a little problem with starting the 550 from time to time.
After shutting the car off after a good drive, sometimes, the car will not want to start? It will crank, sometimes fireup, but at very low revs, and then die. I will then have to crank her for about 10 seconds, pressing the gas pedal right at the end to get her to fire up. Any ideas on where to start? I have just had a service done, but thought that possible it was due to bad filters. Seems there is more to it.... Any advice will be appreciated.
Current - 2001 550 Maranello
1990 Testarossa
1983 400i
2010 VW Polo
Jay Kay is offline
post #2 of 6 Old 10-11-2013, 01:49 AM
Ferrari Life Posts: 967
If you still have your old fuel filters from you recent service, now would be a great time to cut one of the ends off and inspect for rubber debris. I find that just draining the filters after I remove them can tell me something about the condition of the fuel pump isolators, which the pumps "sit" in, so to speak. Often times, the fuel will have a distinctive black tinge, indicating rubber deterioration.Over time, the rubber pieces that support the fuel pumps deteriorate and end up being sucked into the pumps...and filters.
This would be the opportune time to measure both fuel pressure and volume...Also, having the injectors cleaned and tested would be beneficial, particularly if the previously mentioned problems exist.
post #3 of 6 Old 10-13-2013, 01:13 PM Thread Starter
Jay Kay's Avatar
Thank you David
I will be pulling the tank this week to inspect and repair if need be.
It seems I may have a dead cat. The car starts in limp home mode. I have reset and tried replacing the o2 sensor control units. No help, so I can only deduce that one of the cars or both is dead. The car is going to the dealer on Wednesday for inspection and correction.
1990 Testarossa
1983 400i
2010 VW Polo
Jay Kay is offline
post #4 of 6 Old 10-13-2013, 03:03 PM
Ferrari Life Posts: 2,206
Clynton, try swapping your Cat ECU's from side to side to see if the problem moves.
You'll probably need to clear codes after the swap and before starting.
post #5 of 6 Old 10-14-2013, 10:18 AM
You may be looking at an ignition system issue. If you have weak spark on one bank the engine won't want to fire, it will also lead to excessive raw fuel running through the exhaust which is a first rate manner in which to create catalytic converter failure.
post #6 of 6 Old 10-18-2013, 01:16 PM Thread Starter
Jay Kay's Avatar
Hi Everyone
It turns out the problem is a broken wire to the left fuel pump. I am having an electrical guy sort it out.
1990 Testarossa
1983 400i
2010 VW Polo
Jay Kay is offline
