Fix of 456GT with expired fan belt - Ferrari Life
post #1 of 7 Old 09-27-2013, 04:21 AM Thread Starter
AkaiAkuma's Avatar
Ferrari Life Posts: 186
AkaiAkuma is offline
post #2 of 7 Old 09-27-2013, 04:49 AM
Ferrari Life Posts: 2,206
Wow, all that for a fan belt
If you don't mind sharing, what material did you use to patch the plastic timing cover?
post #3 of 7 Old 09-28-2013, 06:44 AM Thread Starter
AkaiAkuma's Avatar
Hi cribbj
I have produced this material.
Wire air conditioning compressor clutch is disconnected fan belt has expired, cover and damaged.
I have found bearing the timing belt pulley from being damaged in the process of repairing them.
And I also found that the water hose is aging.
As a result of consultation to the owner, was asked to be repaired all.
post #4 of 7 Old 09-28-2013, 07:57 AM
Originally Posted by AkaiAkuma View Post
Hi cribbj
Nice work Jun, and would that patching material also work as an adhesive? Sometimes with these covers, one of the mounting bosses will break off, and it would be very good if there was a material suitable for gluing it back on securely. It's probably wishful thinking that it would work, but it might be worth a try.
post #5 of 7 Old 09-29-2013, 07:10 AM Thread Starter
AkaiAkuma's Avatar
Hi Cribbj
This material acts as an adhesive.
The adhesive force is parallel panel bond.
In addition, depending on the type of material to be added, it will be putty.
Cutting is possible after curing.
post #6 of 7 Old 10-08-2013, 04:39 AM
Ferrari Life Posts: 7
Hello Akai, what hoses did you use to replace the old radiator hoses? Are they pure silcone? Where can I purchase?
360modena is offline
post #7 of 7 Old 10-08-2013, 10:43 AM
bay
bay's Avatar
Ferrari Life Posts: 156
-> SamcoSport USA - Colours
This is the hose that SUMCO.
This hose is mede silicone.
Registre 550
bay is offline
