550 power steering - Ferrari Life
post #1 of 9 Old 06-27-2013, 04:38 PM Thread Starter
Ferrari Life Posts: 13
550 power steering
Just got a 550 yesterday!!!!!!!!!!
As it got off the truck, I heard the power steering squeal I bit. But the time I got home ( 10 miles) the wheel was near impossible to turn. The reservoir was empty. I will replace the fluid, but are there any tips for a fix? Should I just bit the bullet and take my new beauty into the dealer?
Appreciate any help.
Msloos is offline
post #2 of 9 Old 06-27-2013, 05:37 PM
Ferrari Life Posts: 2,206
There are two common areas of 550 P/S leakage - one is the rack itself and the other is a weepy hose at the reservoir. If your reservoir was completely empty, it sounds as though your rack might have an incontinence problem........
post #3 of 9 Old 06-27-2013, 10:05 PM
Ferrari Life Posts: 11,881
Hoses are notoriously weak on the 65 deg V12 power steering systems (and other Ferraris). Make sure those are ok before going on to more expensive problems. A good hydraulic shop can build better replacement hoses than OEM.
Rebuilders. Maybe some of the pros can give an opinion on their competence and the advisability of rebuilding if things are bad.
Atlantic Enterprises
9326 Highway 90
Longs, NC 29568
1-800-654-7565
http://www.atlantic-ent.com/index.php
Advantage West,
68805 Perez Road, # F44
Cathedral City, CA 92234-7227
760 202 9990
http://buy-advantage.com
post #4 of 9 Old 06-28-2013, 05:11 AM Thread Starter
Thanks for the input I will check the hoses out this evening. I will assume if the hoses look okay, then off to the dealer I go?
Msloos is offline
post #5 of 9 Old 06-28-2013, 05:30 AM
Check also for wet boots on the ends of the rack.
BTW, welcome to the 550 club - we need some additional V12 members and discussion with all the little V8's buzzing around here lately
post #6 of 9 Old 06-28-2013, 08:56 AM
Fill her up and do the workshop manual trick of turning the steering back and forth to bleed it before you do anything. Then you or the tech can find the leak(s).
If you do not have a 550 WSM, download one for free from ferraridatabase.com for the complete procedure.
post #7 of 9 Old 06-28-2013, 09:15 AM
I have about a 250% failure rate for rack rebuilders.
Just say no and buy a new one. If there is one single system that has to work EVERY time it is the steering.
I'd rather loose wheels and brakes than steering.
post #8 of 9 Old 06-28-2013, 10:16 AM Thread Starter
Oh my!
I will bleed the system and see what happens. Thanks to all for the advice! So happy to be part of the family!
Msloos is offline
post #9 of 9 Old 06-28-2013, 11:03 AM
Brian - Good to know. At least with good steering, you can choose the crash location.
