550 lock problem - Ferrari Life
post #1 of 3 Old 03-04-2013, 01:54 AM Thread Starter
Bluebottle's Avatar
Ferrari Life Posts: 1,502
550 lock problem
My locks are behaving oddly. I wonder if anyone has any ideas what the cause / solution may be. Symptoms are:
Fob locks the door next to which it is held, but not the other one, so you can have one door locked but not the other!
Fob sets and cancels alarm as normal and if you open a door when it is set (which, of course, you should not be able to do), it goes off.
Key locks one door only – not the other, and that door unlocks after you have tried to open it - if you pull the handle a second time, it opens.
That’s about it. Very annoying and not conducive to leaving the car anywhere but in my garge, which is a bit limiting!
Any suggestions will be very welcome.
Best wishes, John
Bluebottle is offline
post #2 of 3 Old 03-04-2013, 04:29 AM
550_Maranello's Avatar
Ferrari Life Posts: 1,232
Hi John,
I had a similar problem in my 550 on last year.
- When i tryed to close by fob all doors closed for two seconds and after are rejected and open.
- same problem if i tryed to close by key.
Very annoying problem for leaving the car anywhere .....
The problem, in my case, was a hardening of the mechanism of door aperture (red colour rectangle in a attached picture) due to a old grease lubricant.
I dismantled mechanism, washed by petrol, and remounted with new grease and all function ok.
I don't know if is useful for your problem, I hope.
Regards
Fabio
550_Maranello is offline
post #3 of 3 Old 03-04-2013, 01:18 PM Thread Starter
Bluebottle's Avatar
Thanks Fabio. May well be the answer.
Best wishes, John
