Difference between 550 and 575? - Ferrari Life
post #1 of 53 Old 01-13-2013, 09:18 PM Thread Starter
uberschprung's Avatar
Ferrari Life Posts: 931
Is it basically the same thing like the 360 and 430? Little changes like intakes?
uberschprung is offline
post #2 of 53 Old 01-14-2013, 12:32 AM
Ferrari Life Posts: 2,206
Brian Crall has stated there are more differences than similarities between these two models. I started a project awhile back to track the differences as they were mentioned by owners/techs, etc.
Here is the progress so far - note this is not a comprehensive or complete list by any means; it's a work in progress and probably always will be:
post #3 of 53 Old 01-14-2013, 12:44 AM
Italian Lover's Avatar
Ferrari Life Posts: 6,738
My gawd, John, that is impressive !
w/ smiles
Jimmy
Italian Lover is offline
post #4 of 53 Old 01-14-2013, 01:31 AM
Thanks Jimmy, whenever someone mentions a tidbit about the 575M that is different from the 550, I try to capture it here. It's really amazing to find all the tweaks that Ferrari made underneath what, at first glance appears to be "nearly" the same sheet metal.
It's an interesting little project
post #5 of 53 Old 01-14-2013, 01:46 AM
575er's Avatar
Ferrari Life Posts: 624
Love your work John.
One item I picked up there...can 575M back boxes fit 550's?
Cheers
Michael
Current Fcars: 360 Modena
575er is offline
post #6 of 53 Old 01-14-2013, 02:38 AM
Thanks Michael, I don't have any first hand experience, but I think the 550 & 575 rear cans are reported to be interchangeable.
Perhaps Taz will chime in later today as he has more background on all the different exhaust mixes and matches than I do.
post #7 of 53 Old 01-14-2013, 07:55 AM Thread Starter
Awesome! Great work cribbj! Thanks alot
post #8 of 53 Old 01-14-2013, 09:49 AM
Ferrari Life Posts: 15,136
360 to 430 probably has as many changes as 550 to 575.
post #9 of 53 Old 01-14-2013, 10:36 AM
Ferrari Life Posts: 11,881
John- Here are a few more things we can add. The 550 idles at about 1000 rpm, while the 575M idles at 800 rpm.
The 575M script and chrome grille ("250 style") were fitted as standard in Summer 03. At about the same time, the center muffler/resonator was replaced with straight pipes and the rear mufflers suitably modified. We might mention that all the rear exhausts on the 550 and 575M are interchangeable, but the headers, catalysts and center sections are not. The 575M has precats in the headers and the 550 (none of them) does not.
FHP was common to both, introduced on the 550 around 1999 and carried over to the 575M, even using the same parts numbers, except the 550 FHP had a bespoke shock absorber ECU and the 575M did not.
Incidentally, the reason the 575M changed from titanium to steel connecting rods was that the Pro-Sport 550s had failures of titanium rods, so they switched to steel for extra strength. This carried over to the 575M. Titanium is lighter than steel and stronger than aluminum, holds up to heat better than aluminum, but is nowhere near as strong as steel for the same size rod.
On the brakes, the 550 and 575M brakes are identical except one piston is larger on the 575M rear calipers because of a slightly more rearward weight balance of the 575M.
On the transaxle, the 575M has heavier duty parts, some shared with the Enzo and carried over to the 612 and some carried over to the 599. Many of these were beefed up to take the stress of 800-900 psi shifts made by the F1 system.
Clutch and brake pedal assemblies are different on the 575M to accomodate F1 and non-F1 cars.
Steering- All 550s (and 456/456Ms) had a steering position sensor to feed inputs more quickly to the shock actuators than the motion sensors could. One was not introduced on the 575M until Nov/Dec 2003. Steering racks were nearly identical.
Huge CCM brakes (398 mm F, 360 mm R, 6 piston F, 4 piston R calipers) were available on the 575M, but only as part of the HGTC package.
On the interior, the 575M had an integrated electronic instrument cluster with strip lighting mostly shared with the 360 and F430. The 550 had minor gauges above the center console.
The 575M steering wheel had separate aluminum horn buttons on the exposed wheel cross-spokes, the 550 has an integrated wheel/airbag assembly with the cross-spokes covered.
The 575M has a memory seat position for the driver's seat.
Incidentally, the changes made from the 360 to the F430 were much more extensive than those on the Modificata Maranello. New engine type with 4 valves/ cylinder instead of 5 and VVT on intake and exhaust valves, cams driven by chains instead of belts, E-Diff fed by an F1 pump even on three pedal cars, new clutch assembly, etc. Shared chassis and similar body style and instrument panel and interior, but that is about it.
post #10 of 53 Old 01-14-2013, 04:37 PM
Looks like I need to get busy & update my list
post #11 of 53 Old 01-15-2013, 04:45 AM
Ferrari Life Posts: 6,204
Pick up the Forza issue #123. Feb 2013.
post #12 of 53 Old 01-15-2013, 10:20 AM
Rik- Not much in there we did not already know.
post #13 of 53 Old 01-15-2013, 10:35 AM
575er's Avatar
We couldn' get that here so if anyone has a copy they want to send me pm me for an address and I'll reciprocate with a surprise from Ireland.
Cheers
Michael
575er is offline
post #14 of 53 Old 01-15-2013, 02:14 PM
Michael- I can order a back issue for you if you like.
John- Another difference is that the 550 has Nikasil coated iron cylinder liners and the 575M has aluminum liners, as Ron discovered.
post #15 of 53 Old 01-15-2013, 11:10 PM
348TBD's Avatar
Ferrari Life Posts: 24
thats some good info, thanks again !
348TB
Damien Ietto
348TBD is offline
post #16 of 53 Old 01-16-2013, 04:34 AM
575er's Avatar
Terry that would be great, I'll PM you.
Cheers
Michael
575er is offline
post #17 of 53 Old 02-04-2013, 05:25 PM Thread Starter
is there a way you can make this a PDF?
post #18 of 53 Old 02-05-2013, 01:04 AM
Ferrari Life Posts: 17
You mean like this. Hopefully this works.
550v12 is offline
post #19 of 53 Old 02-05-2013, 01:22 AM
mjb11800's Avatar
Ferrari Life Posts: 304
That is some seriously impressive research there John & Terry
mjb11800 is offline
post #20 of 53 Old 02-05-2013, 07:02 AM
Cheers Matt, whenever someone mentions something interesting about the 550 vs the 575 I try to capture it.
Taz, I don't think this point is correct - I believe it's now confirmed that Ron's 550 has Nikasil coated ally liners, just like the 575M. They're obviously not the same Ferrari P/N, but I would think they're the same metallurgy.
In fact, I don't know of any engines with Nikasil coated ferrous metal liners - do you? To me, the sole purpose of Nikasil'ing aluminum liners, or the bores of an ally engine is to increase the hardness & improve the wear characteristics of the aluminum surface, but iron / steel liners don't have the hardness/wear issues.
