456MGT replacement clutch - Ferrari Life
post #1 of 7 Old 11-13-2012, 03:58 AM Thread Starter
AkaiAkuma's Avatar
Ferrari Life Posts: 186
Were exchanged with the clutch, release cylinder, the master cylinder.
Release bearing was frozen. Is considered rather than aging, and because of the condition of long-term immobility showrooms etc..
Although the symptoms are the same receipt 456GT made ​​in 1994, again, the symptoms have occurred after the state for a long time, do not move.
Transmission, propeller shaft, the clutch housing can be removable as separate components, 456GT work is easy.
Master cylinder was ordered for the 456M.
However, the mounting holes are the same small shape, type of tap is OFF has been sent. Dekiru not installed, you can use the drill, I was used to enlarge the mounting holes.
It took three days to do this.
AkaiAkuma is offline
post #2 of 7 Old 11-13-2012, 09:40 AM
Ferrari Life Posts: 6,204
Do the different parts require any ECU modifications [guessing not as not mentioned]...
Granucci is online now
post #3 of 7 Old 11-13-2012, 09:49 AM
Ferrari Life Posts: 11,881
Jun- Careful on the brake mods. The 456 has hydraulic boosted brakes and the 456M has vacuum boosted brakes.
post #4 of 7 Old 11-13-2012, 12:17 PM Thread Starter
AkaiAkuma's Avatar
Hi tazandjan
I had to replace the clutch master cylinder is not a brake master cylinder.
post #5 of 7 Old 11-13-2012, 12:20 PM Thread Starter
AkaiAkuma's Avatar
Hi Granucci
ECU does not require adjustment of the clutch is a completely mechanical operation.
post #6 of 7 Old 11-13-2012, 01:34 PM
Originally Posted by AkaiAkuma View Post
Hi Granucci
Sorry, I thought there were a Brake ECU for the anti-locking brakes etc. But I guess the mechanical can be adjusted accordingly
post #7 of 7 Old 11-13-2012, 08:37 PM
Jun- I see, said the blind man. Clutch.
