550 Parking Lights stuck on - Ferrari Life
post #1 of 4 Old 11-01-2012, 07:30 PM Thread Starter
Hey All,
I sent a few interior pieces to Robbie for the stickynomore treatment-- including the 7 trim switches. First I'd like to recommend his work to anyone. Incredible job and very fast turn around time.
My question for the technical guys is this: I just put the switches back in but there seems to be a problem with the parking lights (fogs and rear lights). They are stuck on, regardless of whether the button is installed, switched on, or switched off, or if the car is on or off. If the battery is on, the lights are on.
I imagine its something with the connector, but I can't quite figure out the design and what might be causing the constant contact. If anyone could "shed some light" on this I'd be forever grateful!
Thanks,
Joe
qksilver is offline
post #2 of 4 Old 11-01-2012, 09:11 PM
Ferrari Life Posts: 2,204
IIRC, it's possible to transpose the connectors for the emergency flashers and the parking lights. I've forgotten what happens when you do this, but it might be the situation that you have now.
Have a look at this pic and see if you've got the connectors right. The red connector goes to the parking lights and the blue one should go to the emergency flashers.
As a check, pull both the blue and the red connectors off the switches and see if your parking lights go out. They should!
post #3 of 4 Old 11-02-2012, 08:19 AM Thread Starter
Thanks, it was the switch contact.
Love you work btw. Your lift system is great. Any pics of your car? Looks slammed.
qksilver is offline
post #4 of 4 Old 11-02-2012, 10:38 AM
Good to hear you found the problem.
Thanks for the kind words; no my 550 isn't lowered, that first video just shows the entry to my own home's driveway, and how close the front lip comes to hitting it.
With only me in the car I could usually clear it by angling in, however if there was a passenger, it was nearly guaranteed to drag. Imagine asking your passenger to "..please get out of the car so it won't drag entering the driveway?"
With the lift kit, no more worries!
