Ferrari Life
-   Modern V12s: 456, 550, 575, 599, 612, 812 (https://www.ferrarilife.com/forums/modern-v12s-456-550/)
-   -   456 Window Mechanism Replacement (https://www.ferrarilife.com/forums/modern-v12s-456-550/19114-456-window-mechanism-replacement.html)
Granucci 10-21-2012 09:47 AM
3 Attachment(s)
Attached is a PDF [28 pages] one may download to see the steps, time, hints, and tools. Hopefully the numerous pics will help.
I am NO DIYer in terms of a qualified mechanic. SO, don't feel you cannot do this on your own. My part, used, was about $225. I highly suggest you have it inspected before messing with install. Honestly, mine works, but the guys who removed it made a slight twist to the pantograph and I feel, I might be re-visiting this replacement soon.
Therefore, although the newer, upgraded OEM part is MUCH better in terms of adjusting the 'window gap' issue, my older one actually has a better pentograph. I 'might' be tempted to try the fix of that pivot point and replace it to the newer mechanism and get the final part I want/need.
Do take your time adjusting the window alignment before replacing the interior door panel as I HATE doing two screws with all my heart: Door handle to armrest [gawd I hate those two screws and it never gets easier :( ]
Now, feel free to comment away and/or ask questions.
henri66 10-23-2012 02:32 AM
Tahnks a lot sir!!!
Granucci 10-23-2012 08:37 AM
Originally Posted by henri66 (Post 219543)
Tahnks a lot sir!!!
Anytime. BTW Your attempt to post on ferrari chat is blocked, which is why I gave the google search criteria of "456 window mechanism replacement" + "granucci" ;)
this site doesn't block links.
bay 10-23-2012 09:26 AM
Super for 456 owner :thumbsup:
tazandjan 10-23-2012 11:00 AM
Rik- Saved to hard drive with your name on it.
Granucci 10-23-2012 11:46 AM
Thanks Bay
Taz: I feel honored. I've updated the docs a bit. BUT size restrictions on FL had me cut it into two pieces. Might want to download again.
The second doc, is a reprint of a previous post showing Ferrari's official instructions for fixing the window gaps and their updated mechanism.
Older mechanism is less straight forward.
henri66 10-24-2012 12:28 AM
Thanks for all your help.
Mine is a 456M, but suffers the same issue.
When I will open the door interior I do guess it is very similar.
i will try to do it during Winter.
Granucci 10-24-2012 02:39 AM
Interesting. We have always believed there was never an issue with the M- series! It has been stated in print numerous times. You are the first. Can you describe problem and state year of your car? Thanks
henri66 10-25-2012 02:15 PM
Mine is from déc. 98.
It is not the first 456M with that issue. On our french forum Ferrarista at least 3 M have the same issue.
Maybe not as bas as your but around 2mm in the central point of the B pillar. I will post some pics.
chrismic 02-03-2013 07:30 PM
Henri, did you ever post those pics? I'd be keen to see them. Cheers, Chris
henri66 02-03-2013 11:07 PM
I never did but I can. Do you have the same issue?
chrismic 02-04-2013 03:05 AM
Please do! Not yet....but I'd be interested to see how it looks in reality. All the Ms I looked at, didn't appear to have the issue....and I never inspected any non-Ms, so don't know how it looks at those cars.
Many thanks
Chris
Granucci 02-04-2013 09:45 AM
Many thanks
Chris
Yes Henri, it would be great to see the gap on an M series to understand better.
as for the gap on non-M, it can be as large as to put your little finder inside between the gap to less. Easily a pencil in many cases.
Makes for noise issues too.
Granucci 02-04-2013 12:58 PM
Just got off a conversation with a member at FC whom where he had his window mechanisms rebuilt by F1 Imports of Naples, FL for about $300 each including shipping. That is a bargain IMO. I got NOS ones, with old pins etc. and paid about that per side.
You send them your regulators. They fix and return in about 10 days. The pin that holds the scissororing wheel together is resplined with a stainless steel pin, not the OEM AL type. OR you can get the pins and do it your self but the mechanism is more of a problem to do so I would let them do it.
Might keep this in your bag of tricks.
Granucci 12-10-2013 01:38 PM
unbelievable : a member of FC PM'd me on wanting to know abou the above PDF and the words Ferrari + Life were '*****' out.!!!!
really taking it a bit too far.
anyway, told him to google 456 window fix and my name granucci and it pops right up... unless of course my las name is not "*****" :|
henri66 04-02-2016 01:49 AM
FYI, after a few years, I have also decided to strip apart mine. Thanks to your pdf on your GT, I have also created a pdf on my MGT.
See French forum https://www.theferrarista.com/forum-...comment=500138
and the pdf is there: http://www.nicolas66.fr/Public/Voitu...6%20-%20V1.pdf
I have not finished yet as I guess the window guides are also an issue.
Henri
henri66 04-04-2016 03:04 AM
Granucci 05-24-2016 04:21 PM
Good work Henri, reading as I type
GREAT and/or BETTER in the pics area. You found the same similar problems I did and re-iterated them again: good idea.
Like your presentation......How has it gone for you since the rebuild? I mean, this IS an item to tackle again after a time.
henri66 05-25-2016 01:04 AM
Not so many kilometers since I rebuilt it. But so far, so good.
Did you need to rebuild it again after some time?
