PPI questions - Ferrari Life
post #1 of 12 Old 05-11-2013, 04:37 PM Thread Starter
Ferrari Life Posts: 23
PPI questions
These are PPI results of a car I'm considering:
- Cabin filter dirty
- Air filter dirty
- Left rear outer tie rod slight play
- Scrapes on bottom of front bumper
- Brake pads and rotors good
- Tires front 8/32 rear 8/32
- Overall car condition is very dirty, needs a detail
Compression + leak down test:
CYL PSI %
1 175 5
2 170 4
3 170 4
4 180 5
5 190 2
6 175 2
7 170 3
8 180 2
Here are some SD/3 results:
B1005 Suspensions failure
B100A check engine failure
P1114 Ambient Air Temperature Sensor (Cylinder Bank 2) min
P2069 Fuel Level Sensor B circuit Intermittent
P1134
P0072 Air Circuit Temperature Sensor: Low
P0464 Fuel Level Sensor (intermittent)
The inspector's opinion is that its a good car overall. The clutch wear on the F1 system is good (80% left)The wear on the carboceramic brakes is minimal. The codes shown are not necessarily problematic, but I'm a little concerned that the car is being offered for sale by Ferrari with this many codes coming up, especially since the engine and suspension faults could mean anything. Possible that the codes are coming up because of something minor like a low or dead battery. My understanding is that the dealership takes care of these kinds of codes before the car is even offered for sale. The other issue that I have concerns about is the variance in compression between cylinder 5 and the rest of the engine. Leakdown percentage numbers look good as they are all 5% or less. Curious about opinions on these results. Are my interpretations correct? Is this a car I should pass on?
Thanks!
m3doc is offline
post #2 of 12 Old 05-12-2013, 09:57 AM
Ferrari Life Posts: 151
What tipo is it ?
V8TDF is offline
post #3 of 12 Old 05-12-2013, 03:27 PM Thread Starter
2006 f430
m3doc is offline
post #4 of 12 Old 05-13-2013, 08:35 AM
chenglo1's Avatar
Ferrari Life Posts: 531
depending
depending on price. i think car looks good on paper. the issues presented look minor. i dont know much about the compression test but elected not to get one done on mine. i had multple sources advise against it. Mostly because the age of the car, an '06 F430. I would have done compression if the service person deemed necessary after preliminary inspection. However, at that point, i would have walked from the deal and searched elsewhere. there's plenty of these cars around that if you don;t feel right about the car in question, walk away.
chenglo1 is offline
post #5 of 12 Old 05-14-2013, 05:30 PM
Ferrari Life Posts: 136
N-n-n-0 If that car is to be sold as a Certified car, those items must be addressed before the car is offered. What is the maximum age of a Certified Ferrari? If 5 years, you don't make it.
Unless you are willing to take the risk, say no and walk away politely.
Jerry Lehrer is offline
post #6 of 12 Old 05-15-2013, 09:06 AM Thread Starter
The car can be sold as certified with Power Normal or Power Train warranty depending on the age. My understanding is that the car would be inspected and certified before being offered for sale, however according to the dealer they only do this inspection/certification if you decide to purchase the warranty.
m3doc is offline
post #7 of 12 Old 05-16-2013, 11:41 AM
chenglo1's Avatar
depending on what warranty and which dealer i've heard between 5 to 7K for the warranty. buy the right car with good PPI and doubt you'll use that. OR pocket the 5-7K into a repair fund with the right car and you should be good to go. if your car did not need anything in the coming 12 months, you come out ahead! mine will sit in storage for 6 months so i would have been paying 5-7K for 6 months of warranty to cover 1000-1500 miles tops! save your $$$ M3doc.
chenglo1 is offline
post #8 of 12 Old 05-19-2013, 09:47 PM
Whoa there doc! You mean that the buyer has to purchase the warranty and THEN the dealer does the inspection/Certification?
NFW!-- I would like to know the name of the dealer so that I could include him out.
post #9 of 12 Old 05-20-2013, 07:53 AM Thread Starter
Actually its the other way around. You have to pay to have an inspection done, and then you can purchase the warranty. The inspection is a Ferrari multipoint inspection and includes changing fluids if needed. You are not able to purchase the warranty until this inspection is done. This seems to be standard practice at most dealerships. The cars advertised as Certified Pre-Owned, are actually just eligible for certification and the advertised price does not include the inspection price or warranty.
m3doc is offline
post #10 of 12 Old 11-24-2013, 08:26 AM
Ferrari Life Posts: 8
new to the fourm...what does PPI stand for?
Ferrari007 is offline
post #11 of 12 Old 11-24-2013, 08:38 AM
Ferrari Life Posts: 966
Pre-purchase Inspection...and welcome aboard.
post #12 of 12 Old 11-24-2013, 09:09 PM
Ferrari Life Posts: 58
The air temp sensors are easy enough to clean with Mass Airflow Sensor spray. The fuel level fault is most likely the result of insufficient use or perhaps a corroded connection. The suspension failure might be cured by simply cleaning the damper connectors.
The tires are not worn enough to be a good negotiation point unless they're cut or very old. Learn how to read the date stamp. (hint: the last four numbers are the week and year of build).
Negotiate your best price and insist on the dealer replaces the tie rod, and gives you a fluid and filter change, and a fresh cam drive belt change. Be sure you're getting the tool kit, car cover, flat repair kit, etc. Insist on a full detail job too. Don't buy the warranty. Don't pay for more inspections but DO go over the car very carefully on your own, preferably with the help of a motor-head friend, using a detailed check list. Don't pay for any of the missing equipment, any of the required repairs, or the clean-up.
Mozella is offline
