360 issues resolved??? - Ferrari Life
post #1 of 7 Old 11-12-2012, 09:13 PM Thread Starter
chenglo1's Avatar
Ferrari Life Posts: 531
Guys,
i have the service records that the dealer sent me via email. A couple items scared me:
1. 17K mile and no clutch replacement-when is it recommended? its a manuals so they can't tell the wear or life left supposedly. I am guessing it's going to be close to time for me to do it so i'd like to factor it in to my offer. BTW i offered and they countered but that was b4 i saw the service records.
2. a year ago, owner kept getting intermittent loss of power, check engine light and slow down light going on. It turned out the be a bad pyrometer. replaced and supposedly car drove fine afterwards. Anyone have this issue? i'm concerned it might happen again.
chenglo1 is offline
post #2 of 7 Old 11-12-2012, 09:36 PM
Ferrari Life Posts: 11,866
Clutch could last 60,000 miles, depending on driver technique. When a 360 clutch needs replacing, the pedal gets very heavy as the linkage goes over center.
No clue on pyrometer problems.
post #3 of 7 Old 11-12-2012, 09:42 PM
Ferrari Life Posts: 3,326
Hi Cheng,
I don't believe the SD2/3 can detect remaining clutch on a stick shift transmission. However, it can be visually sighted.
As long as the car has not been mistreated, 17K on a clutch should be nothing to worry about.
Right after we got our Spider, we had the same indications sans the slow down light. It turned out to simply need a new fuel cap seal and a fresh tank of gas run through (the car had been sitting for about a year). The symptoms never came back. But a good PPI should tell you why that particular car has those symptoms.
Killer58 is offline
post #4 of 7 Old 11-12-2012, 09:45 PM
David- How do you visually inspect the wear on a 360 clutch? Possible on the 65 degree V12s, but have not heard of it being possible on the 360.
post #5 of 7 Old 11-13-2012, 07:27 AM
To be honest Taz, I don't know. I was relayed that info at FOW prior to arranging the PPI for mine. They told me there was a little inspection port on the underside. It may be folklore. I should have qualified it with "maybe" or "I think". Hope someone can confirm?
Killer58 is offline
post #6 of 7 Old 11-13-2012, 09:01 AM
Same as any other.
Chenglo, if they really don't know how you are talking to the wrong people. They are better suited to be bridge toll takers.
Find a real mechanic.
And just because it only has 17k miles is no reason to not be concerned with the wear. I have replaced worn out clutches at 1500 miles. I have put over 200,000 miles on some of my own clutches without wearing them out and just installed a used clutch on my freshly rebuilt 328. It will still be there when I die. There is no such thing as standard clutch life.
post #7 of 7 Old 11-13-2012, 10:52 AM
Brian- Thanks, learn something every day.
