Ferrari 456 Immobiliser location - Ferrari Life
post #1 of 10 Old 01-23-2014, 05:08 AM Thread Starter
Ferrari Life Posts: 8
Hi all i am having trouble with my Ferrari 456 gta immobilizer, i took it to DK engineering who couldn't reprogram my fobs to car and as a result i am trying to remove my immobilizer totally.
I needed to find the immobilizer location does anyone know where it is?
I read its under the passenger seat carpet can anyone confirm before i remove the seat to check please.
Any help would be appreciated.
F456gta is offline
post #2 of 10 Old 01-23-2014, 08:24 AM
Ferrari Life Posts: 11,846
If you remove the immobilizer, the car will not start or run, period, so you will have shot yourself in the foot and maybe even crossed your feet to save bullets. Tell us what the problem is and maybe we can help. Read this so you have a bit better understanding of the alarm system and what your options are and do not turn your 456 into a plant stand.
File Type: doc Programming Alarm ECUs with New Fobs.doc (2.04 MB, 366 views)
post #3 of 10 Old 01-24-2014, 07:13 AM Thread Starter
Hiya whats happened is i bought a ferrari 456 gta with only one fob 5 years ago. I should have made copies but didnt know this would ever happen to me.
I accidently left my keys in my trousers and washed them. The.remote no longer worked so i sent remote to be checked and repaired but still no joy.
So i sent my car to DK engineering who ordered my pin and fobs to program, but this didnt work as they claim the immobiliser or pin code was changed at some point.
So now i have a car sitting there not starting and someone mentioned i could remove immobiliser or reprogram mg ecu.
If what you are saying is right what do you suggest?
If i order a new immobiliser it will cost 2k including fitting and im goin through a financial nightmare.
I was hoping to fix my car and sell it
F456gta is offline
post #4 of 10 Old 01-24-2014, 10:54 AM
Did you send your fob to Eric in France to see if he could recover the data written on the EEPROM in the fob? If he can read it, he can then copy it to a working fob and you will be set. Let me know if you need contact information.
Otherwise you have two options, buy a complete new alarm set, which includes a new Alarm ECU, new immobilizer, and three new fobs with PIN and that set will already have the PIN and fob IDs in the ECU. Or you can buy a used alarm set, which I would not do unless you also get the PIN. All alarms from the F355 5.2- the 575 7.1.1 are the same so any will work. You would probably have to swap the Motronic ECUs side to side to make either work.
You cannot remove the immobilizer and have her run. She looks for an alarm good signal from the Alarm ECU before starting and that comes from using the fob to disarm the alarm and immobilizer.
If Eric can recover the data, have him make two fobs and then rotate them almost daily so the rolling codes do not get out of synch. Do not carry both of them in your pocket, as you discovered.
post #5 of 10 Old 01-25-2014, 01:21 AM Thread Starter
Thanks for the help taz.
Can you pm me Erics details and i can see if i can speak to him if he can do this for me? I have all three new fobs i bought if he can copy program these woud be good.
Af
F456gta is offline
post #6 of 10 Old 01-25-2014, 08:35 AM
Af- Did you buy a new set of three fobs with new PIN or are they just loose fobs? Will PM Eric's details.
Do you have the paper alarm PIN as shown in the document above?
post #7 of 10 Old 01-26-2014, 11:05 PM Thread Starter
yep bought the 3 fobs and pin cost 320 with vat.
The pin didn't work with my car though
F456gta is offline
post #8 of 10 Old 01-27-2014, 11:38 AM
The new PIN is not designed to work to program your Alarm ECU with the new set of fobs. To program a new set of fobs, you need the original PIN that came with her and is still in the Alarm ECU, otherwise you cannot start her with the PIN and key or program the ECU to accept a new set fobs.
Ask your dealer if he can get your original PIN for you. Ferrari keeps a record of those PINs. Once you have the original PIN, you can program the ECU to accept the new set.
post #9 of 10 Old 01-27-2014, 11:51 PM Thread Starter
Taz.....Great news!!
Had word from Eric and he mentioned he would be able to copy my damaged fob to my new fobs, if this works im all sorted and hes got a really good price, better than all places i been.
Wish i had come here sooner! Thanks for your help, you been so helpful.
Otherwise the car would have sat for another year!!
F456gta is offline
post #10 of 10 Old 01-28-2014, 12:17 PM
That is what we want to see, another V12 moving like she should. Good luck.
