2.7 ferrari 355 will need timing belt change - Ferrari Life
post #1 of 33 Old 11-12-2013, 05:31 PM Thread Starter
Ferrari Life Posts: 248
hi guys
I am looking to change my own timing belts & HILL bearings on 1995- f 355-2.7 engine
KROME
do you know where I can find some help & pictures
KROME is offline
post #2 of 33 Old 11-13-2013, 05:01 AM
Once the engine is out, the procedure is pretty well explained in the WSM....
post #3 of 33 Old 11-13-2013, 07:01 AM Thread Starter
the engine will not be removed, I removed my GAS tank & everything around
TIMING BELTS can be seen
KROME
KROME is offline
post #4 of 33 Old 11-13-2013, 09:06 AM
Ferrari Life Posts: 11,860
Does not change the procedure for changing the belts and timing the cams, just the location. Do you have the WSM?
post #5 of 33 Old 11-13-2013, 10:00 AM Thread Starter
What is the---wsm--where can i see it
krome
KROME is offline
post #6 of 33 Old 11-13-2013, 10:11 AM
Workshop manual. ferraridatabase.com. Free.
post #7 of 33 Old 11-13-2013, 11:19 AM Thread Starter
I hope to find it
thanks again
krome
KROME is offline
post #8 of 33 Old 11-13-2013, 04:23 PM Thread Starter
DO I HAVE TO REMOVE MY VALVE COVERS TO GET THE # (1) & # (5) TIMING RIGHT
KROME
KROME is offline
post #9 of 33 Old 11-13-2013, 06:22 PM
Ferrari Life Posts: 9,567
wetpet is offline
post #10 of 33 Old 11-13-2013, 08:37 PM
Yes, you do. But you can always just do a lock and swap that will leave you with the timing you already have. Not optimum, but maybe a good idea first time around. Do you have a degree wheel and dial indicators to allow you to determine TDC and cam timing? If not, you are stuck with doing a lock and swap or having someone help you who does have the equipment and expertise to do the work.
post #11 of 33 Old 11-14-2013, 11:20 AM Thread Starter
hi guy
I removed both heads & can't seamed to find any timing marks
krome
this ia a 1995 ferrari 2.7 engine I have to used timing etc.
KROME is offline
post #12 of 33 Old 11-14-2013, 11:26 AM
Ferrari Life Posts: 74
why you are in there, install the 3.5 upgrade.
I didn't want to be the first to suggest it
DONRON is offline
post #13 of 33 Old 11-14-2013, 11:56 AM
Originally Posted by KROME View Post
hi guy
krome
Are you sure you should be doing this yourself?
post #14 of 33 Old 11-14-2013, 01:10 PM Thread Starter
whats the 3.5 upgrade I can get for the 2.7 engine
KROME is offline
post #15 of 33 Old 11-14-2013, 02:51 PM Thread Starter
wetpet
what is the 3.5 upgrade
KROME is offline
post #16 of 33 Old 11-14-2013, 04:46 PM
355dreamer's Avatar
Ferrari Life Posts: 1,132
wetpet
I think they sell it at AutoZone. Might wanna check the parts counter there.
355dreamer is offline
post #17 of 33 Old 11-14-2013, 07:04 PM
wetpet is offline
post #18 of 33 Old 11-14-2013, 07:08 PM
dreamer is pulling your leg. only available through classiche( requires re-stamping the block). need to call the dealer, i don't have all the info.
wetpet is offline
post #19 of 33 Old 11-15-2013, 12:25 PM Thread Starter
where is the dealer
Do you have a number I can call
KROME is offline
post #20 of 33 Old 11-15-2013, 02:18 PM
355dreamer's Avatar
where is the dealer
Call your local Ferrari dealer and just tell them you need the certification to change the 2.7 F355 to the 3.5.
They will have to do some certification, which I think requires removal and relocation of the gas tank.
Other than that, it's a simple process which can be done with any routine non engine drop belt change job.
