motor temperature - Ferrari Life
post #1 of 3 Old 02-28-2013, 11:36 AM Thread Starter
motor temperature
I just bought a Mondial cabriolet 1988 and the oil and cooling water temperature are not exceeding 70 degerees celsius. Pretty low I would say, although it's winter here in Holland and the outside temperature is around 0 degrees celsius. What do you think, what should I do?
Bart van Geleuken
bartg is offline
post #2 of 3 Old 02-28-2013, 05:48 PM
Ferrari Life Posts: 11,860
Bart- Welcome to Ferrari Life. Sounds normal to me if you are driving short distances. If the water temperature does not go higher in city traffic, you may have a sensor sender problem or a stuck thermostat. Cleaning the sensor connector may help, but a good tech should be able to isolate the problem easily.
post #3 of 3 Old 03-01-2013, 03:10 AM Thread Starter
thank's, I will check it!
Bart
bartg is offline
