91 TR Brake piston adjustment? - Ferrari Life
post #1 of 3 Old 09-29-2005, 03:48 PM Thread Starter
Problem: When changing brake pads, the inner front pistons, on both sides, won't retract to allow clearance for new pad. I don't see any adjustment screw or anything... Solution? Suggestions?
FORZA FERRARI
Boxer12 is offline
post #2 of 3 Old 10-14-2005, 09:03 AM
Magnum6464's Avatar
Ferrari Life Posts: 1,990
sorry for ther late reply
Buy a C clamp and push the piston back in, put your pads on and install it back quick !
The C clamp bolt that screws goes inside the piston
There is no screw on the caliper besides the bleeder screw (to let air out of the brake system)
1990 348 TS (87284)
Magnum6464 is offline
post #3 of 3 Old 10-14-2005, 01:02 PM
Ferrari Life Posts: 308
I must chime in here.....the TR has pistons on BOTH SIDES of the caliper. So you need a spreader tool....to compress in both directions at the same time. I bought my tool off ebay (cheapie) and it works great, don't remember the brand. Also when compressing the pistons back into the calipers you ought to loosen the cap on the master cylinder resovoir and maybe put some rags under it to catch any excess fluid. A brake job doesn't get much easier than on a TR.....very service friendly.
carguy is offline
