Cracked Header Tube - Ferrari Life
post #1 of 10 Old 07-01-2014, 10:30 AM Thread Starter
Ferrari Life Posts: 227
Cracked Header Tube
Our 412P header cracked. Do you think Ferrari will Warrantee?
412 P 0854/330 P 3/4 0846/166s 002C
Dino Competizione/Ferrari P 4/5 by Pininfarina
P 4/5 Competizione/Ford MK-IV J6/Lola SL71-32
Duesenberg J446/Studz DV32/Baja Boot
Napolis is offline
post #2 of 10 Old 07-01-2014, 11:22 AM
Ferrari Life Posts: 11,881
Jim- Never hurts to ask. They might still have one lying around taking up space.
Did they issue workshop manuals and parts catalogs for the P cars?
post #3 of 10 Old 07-02-2014, 06:43 AM
bryanp's Avatar
Ferrari Life Posts: 642
piece o' crap. Is SpA still taking your calls since you laid down the FIA Alternative Energies challenge?
bryanp is offline
post #4 of 10 Old 07-02-2014, 08:12 AM Thread Starter
They did for the 512S but earlier stuff which we have is more log/book set up.
Napolis is offline
post #5 of 10 Old 07-02-2014, 08:13 AM Thread Starter
Napolis is offline
post #6 of 10 Old 07-03-2014, 02:20 AM
Phil Dade's Avatar
Ferrari Life Posts: 66
I am curious. What is the source cause that makes a header crack? (not just a faulty header)
Phil Dade
F 430 Berlinetta owner
Phil Dade is offline
post #7 of 10 Old 07-03-2014, 09:19 AM
Phil- Heat, stress fractures, and vibration from the engine and its movement. Often exhaust mounts contribute if they are too stiff to allow for heat expansion and movement of the engine under changing torque loads.
post #8 of 10 Old 07-03-2014, 10:40 AM
Phil Dade's Avatar
Thanks Terry. Headers seem to be a frequent subject.
Phil Dade
post #9 of 10 Old 07-03-2014, 12:44 PM
Phil- In the olden days with mild steel pipes and mufflers, water vapor would condense and accumulate in pipes and mufflers and rust them out, too, especially if the car was not driven enough to get the exhaust really hot. Now just about everything is stailess steel, so that is not an issue.
F430s have problems with headers and a good solution has been the Capristo mounts.
post #10 of 10 Old 07-04-2014, 06:47 AM
Phil Dade's Avatar
Again, many thanks Terry.
Phil Dade
