458 Speciale Reviews - Ferrari Life
post #1 of 5 Old 11-12-2013, 10:03 AM Thread Starter
Mike430's Avatar
Ferrari Life Posts: 1,291
Reviews on the Speciale are starting to make their way on the net and in magazines.
Here are reviews from UK's Auto Express, EVO and a video review from CAR.
Auto Express
Our Ferrari 458 Speciale review, the most extreme road-going Ferrari yet
You don't need to speak Italian to know that the new Ferrari 458 Speciale is going to be, well, a bit special. Based on the brilliant 458 Italia, it's F1 tech and promises to be the most thrilling machine in an already high-octane line-up.
On paper, the Speciale is mouth-watering. Power from the 4.5-litre V8 is up from 562bhp to 597bhp, weight is slashed by 90kg and the 0-62mph figure tumbles by four tenths to 3.0 seconds. And the stunning bodywork has been given an equally aggressive overhaul.
At the front you'll find an F1-style chin spoiler, a pair of turning vanes ahead of the front wheels and a resculpted bonnet. Look down the Ferrari's flanks and you'll spot shark-like fins, while at the rear is a larger spoiler, a huge diffuser and two menacing-looking tailpipes. The Speciale also benefits from clever active aerodynamics, which use hidden flaps to increase downforce or decrease drag, depending on the car's speed.
Inside, there are plenty of race-inspired touches. Carbon fibre and Alcantara trim are used throughout, while the driver and passenger benefit from a pair of lightweight, figure-hugging Sabelt seats. Elsewhere, it's standard 458, which means slick design, a driver-focused dash and bold LCD instruments.
Prod the steering wheel-mounted starter button and the V8 yelps into life before settling into a gravelly idle. And performance is explosive - the Speciale feels almost as fast as the 730bhp Ferrari F12 flagship.
This impression is heightened by the seven-speed twin-clutch transmission. Tweaks to the software means it responds even more promptly to the gearshift paddles, allowing you to rip through ratios in a blink. Adding to the drama is the engine's glorious soundtrack, which turns from sharp bark to spine-tingling yowl as the rev counter whips round to the 9,000rpm redline.
The V8 dominates so much that it's easy to overlook the sublime handling. A combination of uprated aerodynamics, tweaks to the adaptive dampers and specially developed Michelin tyres helps the Speciale generate a staggering 1.33g during hard cornering. In fact, there's so much grip in the dry you'll run out of bravery before the car starts to slide. Even so, Ferrari's new Side Slip Angle Control systems allows a little playfulness before the stability control steps in.
As with the standard car, the steering is razor-sharp and direct, allowing you to place the car with laser-guided accuracy, while the modified Brembo brakes deliver eye-popping stopping power. Yet what's really remarkable is the 458's ability to combine this raw, racing-car driving experience with everyday usability. The ride is firm but never uncomfortable, the major controls are light and visibility is excellent. There's even a handy 230-litre boot.
Key Specs
Price: 208,000
Engine: 4.5-litre V8
Power: 597bhp
Torque: 540Nm
Transmission: Seven-speed twin clutch auto, rear-wheel drive
0-62mph: 3.0 seconds
Top speed: 202mph
Economy: 23.9mpg
CO2: 275g/km
Equipment: Active aerodynamics, 20-inch alloys, carbon-ceramic brakes, Alcantara seat trim.
On sale: February 2014
Mike430 is offline
post #2 of 5 Old 11-12-2013, 10:07 AM Thread Starter
Mike430's Avatar
Evo
The Ferrari 458 Speciale is the latest in a line of super-hardcore mid-engined Ferrari V8s.
What is it?
The Ferrari 458 Speciale takes what is already one of the most extreme road cars you can buy and turns it up a notch further. In the spirit of the Ferrari 360 Challenge Stradale and 430 Scuderia, the Speciale takes the 458 into new, more hardcore territory. It also gets a central stripe, just like its iconic forebears.
Technical highlights
The 4.5-litre V8 now produces 597bhp at 9000rpm, its 133bhp-per-litre made possible by a staggering 14:1 compression ratio. This greater output is pushing 90kg less too, thanks to a carbonfibre underbody, thinner glass for windscreen and side windows, a Lexan engine cover, new and lighter ceramic brakes, forged wheels and an interior of delicious minimalism.
There are also new magnetic dampers, stiffer springs and new anti-roll bars. The gearshift logic is revised and cuts the time it takes the engine speed to match the gear ratio on downshifts by 44 per cent. Then there's the new active aero, which cuts drag as speeds increase, and the next-generation high silicon content ceramic discs. no wonder Ferrari says this car isn't a 'version' of the 458 Italia, but a whole new car.
A new Side Slip angle Control (SSC) system allows drivers of all skill levels to explore the depth of the Speciale's ability with as little electronic intervention as possible, but still with a degree of assistance should they overstep the mark.
What's it like to drive?
The firmer ride has no hint of harshness. It's wedded beautifully to a heavier, even more accurate steering system, more consistent and responsive brakes and the sweet brutality of the twin-clutch gearbox. The Speciale isn't stiffer, faster, louder. it's just beautifully wrought, cohesive and - no question - it feels more serious, more focused and just plain better.
It is noticeably noisier than the Italia, though. It doesn't howl and shriek quite as manically as a Scuderia, but the engine can drone away if you're in Race mode or upwards. There's ever-present road noise that drums up through the bare floors, but in a car of this potential and focus it's far from a deal-breaker.
Strangely, the gains in simple performance terms don't feel as great as I'd expected, but no matter. This is still a seriously rapid car. The engine is remarkable and the way it melds thick, instant torque with that explosive top-end delivery is quite breathtaking.
The faster rev-match on downshifts does make a difference and it actually makes braking late into a corner a slightly more brutal process, each shift bringing a jolt as the gears hit home. It feels like the shifts are completed with no margin at all. If the clutch closed a millisecond sooner the rear wheels would lock. There is no margin, no slack anywhere in this car.
The Speciale wears unique Michelin Pilot Cup 2 tyres - the same basic tyre as we've recently tried on the GT3 and SLS Black Series - and the car simply dances over a seriously testing road that's slick with moisture and fallen leaves. Grip is astounding and the heavier steering provides something to lean against and accurately relays an impression of the surface and the tyre's grip.
What of SSC? Well, 'witchcraft' just about sums it up. It's almost supernatural, allowing you to drive so hard but remaining - for the most part - invisible.
How does it compare?
At 208,000, the Speciale costs more than a McLaren 12C - which with 616bhp from its twin-turbo V8 still manages to outgun the Ferrari. The Speciale is also around 30,000 more than the standard 458, and although that sounds like a lot, the difference in feel and overall composure is quite marked.
With a 1min 23.5sec lap time around Ferrari's Fiorano test track, the Speciale is 1.5sec quicker than the standard 458, 0.5sec quicker than the 599 GTO and just 0.5sec slower than the 239,000 730bhp F12 Berlinetta. At 1.33 G, Ferrari is claiming the highest lateral acceleration of any of its road cars.
Anything else I need to know?
The Speciale's vast array of electronics are incredibly complicated but the aerodynamic solutions utilised to meet the divergent aims of decreased drag and increased downforce have a delightful simplicity of execution. Centrally mounted at the front are two moveable vertical flaps, which sit above a moveable horizontal flap.
At speeds below 105mph the flaps remain closed to channel air to the radiators. The force of air pressure opens them at 105mph, reducing the volume of air to the radiators and cutting drag. At 137mph the horizontal flap is forced downwards also due to air pressure, which redirects the airflow and leads to a 20 per cent shift in overall downforce towards the rear of the car for the optimum high-speed aero balance. Clever stuff.
Evo Rating:
+ Extreme, frantic fun, makes the 458 even more accessible.
- Slightly noisier than the Italia...
Mike430 is offline
post #3 of 5 Old 11-12-2013, 10:08 AM Thread Starter
Mike430's Avatar
CAR
Mike430 is offline
post #4 of 5 Old 12-05-2013, 06:13 AM
Elite Traveler spoke to Ferrari's test driver and engineer about how they designed the car and worked with Michelin for the tyres
fanaticred is offline
post #5 of 5 Old 12-10-2013, 08:56 PM
viscount aero's Avatar
Ferrari Life Posts: 453
Awesome car. Incredible presence.
viscount aero is offline
