F355 with fuel tank up front like --porsche 911 - Ferrari Life
post #1 of 30 Old 06-06-2013, 05:10 PM Thread Starter
Ferrari Life Posts: 248
Hi 355 guys
i have been working on removing my existing tank in the rear --&--putting
another fuel tank up front like the ---porsche 911
the tank is made of 1/4" thick aluminum with baffles +30 gallons fuel +
52 pounds the tank alone weighs---go figure complete weight up front
i also installed two 16" fans in the space where the old tank was
f355 handles better than before==nice weight balanced=around corners
now i have easy access to the engine ===anytime==i am so happy
no more engine removal===no stress==i did it all=by my self=no help
krome
KROME is offline
post #2 of 30 Old 06-07-2013, 01:07 AM
Ferrari Life Posts: 76
Wow, just, wow. You actually did this? Pretty amazing. Just don't rear-end anybody-or else your windshield will be flame-colored!
greg328 is offline
post #3 of 30 Old 06-07-2013, 02:39 AM Thread Starter
all the PORSCHES---911 have fuel tanks up front--REMEMBER FOR YEARS NOW !
hi
they are still making --PORSCHE 911----WITH A-- PLASTIC FUEL TANK UP FRONT
THINK ABOUT THAT !
MY 355 IS A LOT SAFER NOW--WITH A FRONT FUEL TANK--I HAVE MORE PROTECTION
@ LEAST $5,000 A YEAR I WILL SAVE ON --MAINTENANCE
THIS IS MY (SECOND) FERRARI 355 IS VERY HIGH MAINTENANCE---LIKE A WOMAN--
I LOVE THE BODY- I WILL DO ANYTHING TO KEEP HER---SHE IS A KEEPER
KROME
LOOK @ HER STANCE-FROM THE REAR !
KROME is offline
post #4 of 30 Old 06-07-2013, 09:35 AM
Ferrari Life Posts: 11,872
One of the reasons the fuel tank is in the rear is to put it closer to the CG so handling does not change as fuel weight changes. Cantilevering it up front like that will make for a pretty good shift in CG as fuel load changes and is likely to affect handling.
post #5 of 30 Old 06-07-2013, 11:04 AM Thread Starter
Center of gravity all fine & dandy
Hi guys
i can say for sure this 355 handles a lot better than before with cg
the front was too light --now it is well balanced all around
nice cornering--not slipping & sliding on wet roads-handles with more
confidence---i feel very good in what i did for the f355---ferrari sits nicely
@ 80-100 mph on i-95--squats nicely --with this --rear stance--
krome
i can clean my complete engine anytime -anyplace-i choose--running cool
i also have 2--16" fans cooling --alternator--headers-engine-oil cooler etc.
Any mechanic can change my timing belts for--- $100 bucks
KROME is offline
post #6 of 30 Old 06-07-2013, 12:18 PM
Ferrari Life Posts: 6,203
+1, and what the other thread I stated might be a problem too is steering with heavy weight front of axles
but
I understand his desire.
post #7 of 30 Old 06-07-2013, 01:21 PM Thread Starter
Weight over front-power steering-no problem
Hi guys
front coil overs was adjusted -for weight & height up 1" handles superb
ferrari 355 handles better than manufacturers
well balanced now------it was too light weight up front---handles great
krome
does anyone ever reads anymore--or--just what they want to !
KROME is offline
post #8 of 30 Old 06-07-2013, 02:29 PM
Ferrari Life Posts: 2,206
Krome, bravo for taking this on and making it work. Did you use a racecar fuel cell for your new tank? It would be interesting to know more about it.
post #9 of 30 Old 06-07-2013, 03:02 PM Thread Starter
Custom made fuel tank with baffles
Here guy
custom made fuel tank with 2 walbro inline fuel pumps gsl 392=60 psi each
30 gallons fuel-everything cost me cheap $500 bucks- i did it all
krome
finally
KROME is offline
post #10 of 30 Old 06-07-2013, 04:58 PM
Ferrari Life Posts: 15
I like the idea of being able to get to your engine. However I am concerned about a front end impact. A bladder would be nice.
speedwayspyder is offline
post #11 of 30 Old 06-07-2013, 06:44 PM Thread Starter
This is 1/4 " thick aluminum -weighs 52 pounds-over kill thickness
Hi
i taught of that also-internal bladder or foam inside--this is a lot easier
to work with--no contamination or clogging to my -electronic injectors
& no surprises
old fuel tank is very thin & light gage aluminum
krome
now this baby is very very cheap to keep---guys
miami
KROME is offline
post #12 of 30 Old 06-07-2013, 07:11 PM
a1exander's Avatar
Ferrari Life Posts: 1,094
I understand the principle of easier servicing.
I equally understand the principle of having more weight on the front.
What I do not understand is the principle of a front end smash and how it may effect the fuel tank and its contents.
Will the tank rupture and spew its contents all over the place?
An interesting conversion but at what risk?
a1exander is offline
post #13 of 30 Old 06-07-2013, 07:20 PM
I worked on a 355 Spyder that was own by Shaq, the removed the convertible top and fuel tank, put a racing cell in the front boot, and notched the firewall for extra leg room. It was great for him, but became a worthless bucket of parts after he was done owning it.
Fuel dropping and spraying will definitely be a concern with the tank's location and construction. Having that in front of my face in a Spyder is probably not my favorite idea. At least in the 911's there is 2ft. of unibody, steering and suspension to crush before getting to the tank. Having a bladder inside would have given me great peace of mind.
There are a number of production cars with fuel tanks that aren't greatly protected though. I believe the Pinto was one of those?
post #14 of 30 Old 06-08-2013, 03:43 AM Thread Starter
You can be hit from any side-i have to hit something
Hi guys.....now @.. 66---i have been owning & driving --ferrari's for 33 years
life is a luck of the draw----you can---die ----anytime or live---forever---ok
life holds no guarantees----i have always been a risk taker--to get ahead
in any endeavor
@ least i did it---you can be hit from any side----ok--i stay back about 20'
from the car in front of me--remember i have to hit a car or something
i am more protected with thick aluminum & heavy crash bars in front
the ferrari 355-----look around you everyday on the --tv--whats going on
tornadoes-----fire-----schools---boston race----hurricanes-i can go on on
--------------------remember-----this----life holds no guarantees-------------
krome
i had a triple bypass & a stroke on my complete left side---va hospital
read my last rites---told my wife prepare for funeral---she sold my
1998- f1 355-for $45,000 to a guy in canada---& after i got better i missed
the most beautiful body & looks i had to have back----another f355
think about this
KROME is offline
post #15 of 30 Old 06-08-2013, 05:08 AM
Krome, what you've done is very innovative, but by putting a self fabricated fuel tank up there that has no certifications at all, you've left yourself (and your family/estate) wide open to a huge liability risk.
I hear what you're saying about enjoying the time you have left, and if you ever rear end someone and that tank ruptures & explodes, you probably won't be around to worry about it, but if someone else is injured/killed, think about the expensive mess you've left for your family & estate to clean up.
I would respectfully suggest you at least consider replacing that tank with an ATL or other certified fuel cell.
post #16 of 30 Old 06-08-2013, 06:19 AM
Ferrari Life Posts: 966
I with you on John this point. The idea of a rigid, non-purpose built fuel tank is very unsettling. The risks of personal injury are way too high....
post #17 of 30 Old 06-12-2013, 06:52 PM Thread Starter
You need weight up front for wet roads on f355
That's why you need more weight up front & support for wet roads on f355
this ferrari is well balanced now with 250 pounds over the front wheels
does not skid on wet roads----before this f355 was too light on the front
it will slide around on wet & slippery pavement
now it sits & handles great around any corners or wet roads
got the picture !
KROME is offline
post #18 of 30 Old 06-13-2013, 03:19 AM
355dreamer's Avatar
Ferrari Life Posts: 1,132
That car is on eBay now btw.
355dreamer is offline
post #19 of 30 Old 06-13-2013, 12:23 PM
Autoholic's Avatar
Ferrari Life Posts: 490
As I said in the other thread, it appears that with the fuel tank removed, you can access the engine. The firewall has to be modified but the point being the fuel tank is removed. The way I see it, if you make some changes so that the fuel tank can be dropped, you could access the cam belts without removing the engine. No need to screw up the handling characteristics of the F355 and you can keep your trunk. For anyone looking to get around the engine out, I'd spend some time trying to do a quick fuel tank drop. Krome is already committed to this method and I doubt he would change it now.
~Joe
"Autoholism is an incurable addiction medicated daily with car porn."
Autoholic is offline
post #20 of 30 Old 06-19-2013, 12:56 AM Thread Starter
(2) 16" fans with (2) 30 amp repays
I have installed (2) -16" fans in the empty cavity to cool everything
alternator--headers--a/c compressor & of course the entire engine
f355 is running very cool with heavy traffic in the miami ------heat-----
the best thing i ever did in any ---ferrari----------it's been a pleasure
this is surely a ---daily driver---
no regrets
krome
KROME is offline
