F355 Convertible Top - Ferrari Life
post #1 of 2 Old 09-13-2011, 07:19 PM Thread Starter
monza's Avatar
Ferrari Life Posts: 402
My spiders top failed once I tried putting the top back up after a nice leisurely drive. I made sure I had the routine right, brakes on, seats extended and doors shut. Still the top will not come back up. I decided to raise the top manually. Upon opening the rear console box which houses the bypass switch and top fuse box, I noticed that one of the fuses had blown and the hydraulic fluid reservoir a bit low. I replaced the fuse and still had problems raising the top.
So I decided to manually raise the top by depressing the bypass switch and using the supplied lever with success.
I will try to schedule a trip to the service department to have it repaired, but before I do that, does anyone have any suggestions or experiences with the 355's convertible top failing.
Chicago_Pete
hey slow driver
monza is offline
post #2 of 2 Old 09-13-2011, 10:35 PM
Ferrari Life Posts: 15,136
Is the top moving at all when you press the "up" switch?
