California with manual transmission.. - Ferrari Life
post #1 of 19 Old 03-16-2010, 07:55 AM Thread Starter
Mike430's Avatar
Ferrari Life Posts: 1,291
Leaked: Ferrari California Manual Transmission Performance Specs
The "chick's Ferrari" as it's derisively/adoringly called by various camps, will soon get a manual gearbox to supplement the dual-clutch unit that's currently the only option. A document leaked recently reveals that the car's performance specs will take a bit of a hit when swapping cogs yourself.
A hit of about two-tenths of a second to 62 mph, that is. The seven-speed automated dual-clutch in the California helps rocket the V-8-powered car to 62 mph in just under four seconds, while the six-speed manual will require nearly 4.2 seconds, according to the leaked document. Top speed remains unchanged, however, at 193 mph. Fuel economy is down a bit on the EU combined cycle as well, from 17.8 mpg with the dual-clutch to 15.8 with the manual.
While the manual is by definition not as sophisticated as the dual-clutch alternative, it's still a high-tech set of gears: double-cone synchros with multiple pawl asymmetric geometry, an oil bath lever and fork system, and rear-mounting to preserve the California's 47/53 front/rear weight distribution.
The manual gearbox California will be available this month in Europe, with the U.S. likely to join the party shortly after.
[Source : MotorAuthority]
Mike430 is offline
post #2 of 19 Old 03-16-2010, 09:19 AM
Ferrari Life Posts: 6,204
I like it, but thinking that will be one rare example and probably turn into some collector car down the road...sort of like the Valeo Mondial Ts, where the Coups are so rare, that I am thinking only about a hand full exist.
Not many will opt for the 'chicks' car as you put it in manual, which would mean I'D buy the manual just because.
post #3 of 19 Old 03-16-2010, 09:35 AM
Ferrari Life Posts: 3,627
Then this bodes well for a manual 458!
I have heard that Ferrari has already replaced a few double clutch trannys. Does not sound good!
Gcalo is offline
post #4 of 19 Old 03-16-2010, 09:55 AM
Yup: Secret..... NOT. Directly from over four persons having their tranny fixed on a new car.
As for the Manual on the 458, hmm, hoping. Would NOT be a good item to leave out a manual, but like Ferrari said: "we will never build a [fill in the blank that can later be modifed to true] car".
Heard also the performance package for the 575 is now in kit for FROM Ferrari for about, what, $12-15k or such.
SO: Why not let drivers, mod their stock Ferraris....
post #5 of 19 Old 03-16-2010, 09:59 AM
Also surprised that I designed an after-market replacement transmission oil cooler for 360's and following, and now I see it is standard equipment on the 458!
No more water cooled transmission coolers.
Isn't that interesting!
Gcalo is offline
post #6 of 19 Old 03-16-2010, 10:57 AM
Ferrari Life Posts: 160
This gets a manual, but the 458 doesn't! WTF!?
Baller is offline
post #7 of 19 Old 03-16-2010, 11:36 AM
Andrew's Avatar
Ferrari Life Posts: 6,320
I was thinking the same. Might this mean the 458 could see a manual in the near future?
Andrew is offline
post #8 of 19 Old 03-16-2010, 02:58 PM
I wonder than if Ferrari will stick to their promise then?
Gcalo is offline
post #9 of 19 Old 03-17-2010, 03:52 AM
Chrishawk4's Avatar
Ferrari Life Posts: 3,874
I wonder if this will be an automatic change. Or if it will take some time.
To accomplish great things, we must not only act, but also dream; not only plan, but also believe.-Anatole France
"Dude, it's just math"-Pete
Chrishawk4 is offline
post #10 of 19 Old 03-17-2010, 10:42 AM
Tony K's Avatar
Ferrari Life Posts: 465
Some people will be all geared up to buy one!
Tony K.
1980 308 GTBi
Tony K is offline
post #11 of 19 Old 03-17-2010, 10:43 AM
Tony K's Avatar
Did they say what the price differential will be?
Tony K.
1980 308 GTBi
Tony K is offline
post #12 of 19 Old 03-17-2010, 10:45 AM
Tony K's Avatar
Would this be considered a shift in policy?
Tony K.
1980 308 GTBi
Tony K is offline
post #13 of 19 Old 03-17-2010, 01:23 PM
We will have to ask Richard Gere!
Gcalo is offline
post #14 of 19 Old 03-17-2010, 04:20 PM
Chrishawk4's Avatar
I see how you shifted the spelling.
post #15 of 19 Old 03-17-2010, 04:29 PM
I am trying to synchronize the thought patterns here.
Gcalo is offline
post #16 of 19 Old 03-17-2010, 07:27 PM
Tony K's Avatar
Or Axel Rose!
Tony K.
1980 308 GTBi
Tony K is offline
post #17 of 19 Old 03-17-2010, 08:34 PM
Can't bold on the itouch but:
hope these plans don't get "stalled."
Baller is offline
post #18 of 19 Old 03-17-2010, 08:50 PM
Tony K's Avatar
Do the following with no spaces: [ b ] text [ / b ]
(or does itouch not have brackets and slashes?)
Tony K.
1980 308 GTBi
Tony K is offline
post #19 of 19 Old 03-17-2010, 09:30 PM
Originally Posted by Tony K View Post
Or Axel Rose!
You forgot about Shaft!
Gcalo is offline
