Need help! - Ferrari Life
post #1 of 10 Old 01-15-2010, 04:09 PM Thread Starter
Ferrari Life Posts: 60
Need help!
I just purchased my first Ferrari.........2000 360 Modena. Does anyone know where the "fuse box" is located? The Owner's Manual did not come with the car. Thanks!
Bob Y.
Sportspa is offline
post #2 of 10 Old 01-15-2010, 05:19 PM
netman's Avatar
Ferrari Life Posts: 226
There are floor panels behind the seats. They are held down with screws. Pull these up and there is a bunch of fuses and relays.
netman is offline
post #3 of 10 Old 01-15-2010, 10:06 PM
Ferrari Life Posts: 3,627
It depends upon which fuses you want.
In the trunk on the right hand side there is a series of fuses behind the fabric panel.
Those are most of the active fuses. The applications are therein stated.
Why do you need the fuses? Symptoms?
Gcalo is offline
post #4 of 10 Old 01-16-2010, 03:59 AM Thread Starter
The interior light, cigarette lighter and the hook up under the drivers side dash (for hook up for inspection) all are out. I would like to check the fuses first. Thanks so much!
Bob Y.
Sportspa is offline
post #5 of 10 Old 01-16-2010, 07:23 AM
ferraricyprus's Avatar
Ferrari Life Posts: 121
Remove panel behind left seat. It's fuse number 72, which is 15 amps.
ferraricyprus is offline
post #6 of 10 Old 01-16-2010, 07:23 AM Thread Starter
Is there a special tool to remove the screws on the fabric panel to get to the fuses? I checked the tool/fuse kit in the car and the traditional screwdrivers did not fit the head. Thanks!
Bob Y.
Sportspa is offline
post #7 of 10 Old 01-16-2010, 07:30 AM Thread Starter
Is the left seat the drivers seat? Thanks!
Bob
Sportspa is offline
post #8 of 10 Old 01-16-2010, 07:37 AM
Bob
Is it left hand drive? If yes, then it's behind the drivers seat. If it's right hand drive it's behind the passenger seat. There are four cross-head screws in the trim. to gain access, slide the seat as far forward as it will go, then remove the screws. Pull the trim forward slightly then up. You will see three boxes. These are your fuse boxes, just remove the covers to gain access to the fuses. I'll send you the P.D.F of the owners manual now...
post #9 of 10 Old 01-16-2010, 08:17 AM
SORRY! Fuse 12 NOT 72 (i mistyped!) it is in the outermost fuse box. Remove the lid. The fuse rows are four wide. The second row from the right, second fuse down, is the one you want to check.
Also check the pins aren't bent up in the cigar lighter. This is a common cause of failure due to phone chargers/accesory plugs...
post #10 of 10 Old 01-16-2010, 01:39 PM Thread Starter
Man, you guys are the best! I found the fuse and replaced it and everything is working! THANKS SO MUCH!! Life is good!
Bob Y.
Sportspa is offline
