question - Ferrari Life
post #1 of 13 Old 01-13-2010, 05:17 AM Thread Starter
Ferrari Life Posts: 10
question
hi
Anybody know if the speed that Ferrari says its cars are real or the speedometer?
and the power is on the crankshaft or wheels?
thanks =)
shot is offline
post #2 of 13 Old 01-13-2010, 05:40 AM
il Capolino's Avatar
Ferrari Life Posts: 2,455
The digital indication on the speedometer seems quite accurate but I have only compared occasionally with speed cameras.
Power and torque is measured on the crank shaft. I have heard you will have a loss through the primary and secondary transmission of between 10% to 15% (i.e. on the wheels). Someone else might have more exact information, though.
Best regards,
il Capolino
Salve,
Capo
The bad news: Time flies
The good news: I'm the pilot
il Capolino is offline
post #3 of 13 Old 01-13-2010, 07:15 AM Thread Starter
the loss of 10 to 15% of power from the crankshaft to the wheels its in bikes, I think in cars its between 20 to 30%
thanks
shot is offline
post #4 of 13 Old 01-13-2010, 07:22 AM
Wow, that's a lot, I didn't know that.
Cheers,
il Capolino
Salve,
Capo
post #5 of 13 Old 01-13-2010, 10:37 AM Thread Starter
the loss of power on the bike, I see in a magazine and the bike was to competition (cbr1000rr of superbikes)
but the cars I see on a site, may be the site was wrong, but I do not think
shot is offline
post #6 of 13 Old 01-13-2010, 11:03 AM
Ferrari Life Posts: 6,204
without a true dyno one could not always say, but there is a loss. Ferrari typically boosts their numbers, by rounding upwards.
As for the speedo, typically, I've seen, Euro speedos +10mph from start and varry up to an accurate report about the 40-50 MPH [KPH equiv.] mark.
I have noticed with checking during rides with other vehicles and speed traps, which are NOT accurate, but an indicator, that Ferraris +5-10MPH easily.
Shoot, they go 10MPH standing still as the speedo reads such due to indicator's peg preventing it lower than 10MPH.
Good news is, Ferraris are fast even while parked
post #7 of 13 Old 01-13-2010, 11:06 AM
viscount aero's Avatar
Ferrari Life Posts: 453
horsing around
thanks
That is a bit oversimplified, isn't *necessarily* true, and entails myriad issues
Most SAE rated HP is at the flywheel; as well, drivetrain losses will depend on many things and can vary depending on both sprung/ unsprung weight (weight of the monocoque and engine/ wheels and suspension), and transmission type.
For example, the new DSG transmissions emerging on supercars today, such as implemented in the F149 California, F458 Italia, Nissan GT-R ... incur less power loss penalty due to the efficiency of the transmission to transmit the available horsepower.
The super quick shifting mechanism allows the DSG transmission to keep the rpms higher in the rev band between shifts, allowing peak horsepower in any given gear to remain continuous. In this case, a % of the drivetrain losses are offset by the car remaining in peak horsepower longer
viscount aero is offline
post #8 of 13 Old 01-13-2010, 11:11 AM
IPF
IPF's Avatar
Ferrari Life Posts: 290
It is a bit more sophisticated and also a.o. depends on how measured, FWD v RWD v AWD, etc.
However, in crude practice, 20-25% losses are commonly observed/assumed in dyno-tests indeed:
"Because of frictional and mechanical losses in the various drivetrain components, the measured rear wheel brake horsepower is generally 15-20 percent less than the brake horsepower measured at the crankshaft or flywheel on an engine dynamometer.[4] Other sources, after researching several different "engine" dyno software packages, found that the engine dyno user can integrally add "frictional loss" channel factors of +10% to +15% to the flywheel power, raising the claim that 20% to 25% or even more power is actually lost between the crankshaft at high power outputs."
As an illustration of such higher power losses, this might be an interesting piece: http://www.carcraft.com/techarticles...oss/index.html
A horse is a horse, of course, of course, and no one can talk to a horse of course. That is, of course, unless the horse is the famous Mister F.
IPF is offline
post #9 of 13 Old 01-16-2010, 11:03 PM
Ferrari Life Posts: 15,136
In terms of the speedos, my personal experience is that it depends on the individual car. F40 reads 10 kph low, F50 is spot on, and the 360 was 5 kph high.
post #10 of 13 Old 01-19-2010, 03:00 AM
Neonzapper's Avatar
Ferrari Life Posts: 1,008
My euro 308 with 16 inch wheels has +10 mph. I've checked it a few times against speed cameras.
_________________________
Neonzapper is offline
post #11 of 13 Old 01-19-2010, 05:18 AM
JazzyO's Avatar
Ferrari Life Posts: 6,397
No they don't, not anymore although they certainly used to in the old days. The 599 was dyno'd by EVO Magazine and shown to be delivering more hp than Ferrari claims (I think it was around 15bhp more than Ferrari's figures). There was another Ferrari they did the same to, same result, but can't remember which one it was. Harry Metcalfe also had his 550 dyno'd and it delivered very close to claimed figures even though the car was 6 years old at the time.
Claimed speed is also more accurate these days. The 550 was given 199mph but it does not achieve it. A German magazine tested the car at 308 km/h, which is just over 191mph. Subsequent cars have been closer to their claimed speed. After all, the topspeed has hardly risen even with massive power increases and aerodynamic improvements.
Onno
JazzyO is offline
post #12 of 13 Old 01-19-2010, 10:03 AM
Onno
I'll say I do not know of the current items, and your explaination does make sense: So, I'll reword to say 'in the past'
post #13 of 13 Old 01-20-2010, 11:07 AM
Angelis's Avatar
Ferrari Life Posts: 603
I remember that article.
First time they did the test, the 599 bhp was a lot lower. Then they changed the tyres and the bhp shot up.
As for % transmission loss, it's anywhere between 15 and 25% depending on who you talk to.
Angelis is offline
