New Purchase - Ferrari Life
post #1 of 14 Old 08-16-2009, 04:37 AM Thread Starter
Ferrari Life Posts: 7
New Purchase
I looked at and test drove a 1990 348ts 13000 miles 1 owner car seems to have all service records Is there anything i should really be concerned about with owning a 348 ? I own a GT500 1967 now I m more familure with owning Muscle cars but want to move in a different direction. Any thoughts
ecph2001 is offline
post #2 of 14 Old 08-16-2009, 08:23 AM
Ferrari Life Posts: 3,627
Look at this so you can get an idea.
See: http://www.ferrarilife.com/forums/sh...ad.php?t=10324
Welcome to the forum.
But take your time as indicated there.
Gcalo is offline
post #3 of 14 Old 08-16-2009, 10:22 AM Thread Starter
Thanks for the heads up I was told that the car had the cam belts and a compression test completed 1000 miles ago I have requested Copts of all the service records
ecph2001 is offline
post #4 of 14 Old 08-16-2009, 10:25 AM Thread Starter
Question: if a person is mechaincly savey can most work be done or do you really need to go to a dealer?
ecph2001 is offline
post #5 of 14 Old 08-16-2009, 10:25 AM
I would certainly want to know why a compression test was done!
Gcalo is offline
post #6 of 14 Old 08-16-2009, 10:51 AM
A Ferrari is just a car.
I do all my own maintenance.
If you are capable, competent, and careful, you can do your own.
You do need a workshop manual, however, and I have one for the 348.
You are certainly welcomed to a copy.
Gcalo is offline
post #7 of 14 Old 08-16-2009, 11:26 AM
Ferrari Life Posts: 15,136
+1 on Gcalo's comments. If you are a skilled mechanic, you should be able to do most if not all the work yourself.
post #8 of 14 Old 08-16-2009, 11:47 AM Thread Starter
Thanks i thought that a compression test would be a noal thong when you do the csmbelt service ?
ecph2001 is offline
post #9 of 14 Old 08-16-2009, 02:42 PM
Cam belt service is not related to a compression check. No need at that time.
It's more critical to check for TDC and to check the timing marks.
You might want to inquire why a compression test was done.
Gcalo is offline
post #10 of 14 Old 08-16-2009, 03:05 PM Thread Starter
I will thanks
ecph2001 is offline
post #11 of 14 Old 08-17-2009, 06:41 AM Thread Starter
Who can I get to do the PPI that is local and what should I expect to pay. I would like to close the deal on this car this week
ecph2001 is offline
post #12 of 14 Old 08-17-2009, 08:55 AM
Where are you located?
Gcalo is offline
post #13 of 14 Old 08-17-2009, 09:24 AM Thread Starter
I'm in del but the car is up In Lancaster I received the service records today seems the major service was completedin December of 2002 at 10000 miles looks like slot of thongs were done includeing the comp test I think Iay pass on this one the car fax showed 3 owners I was under the asimption it was a 1 owner car thanks for all your input
ecph2001 is offline
post #14 of 14 Old 08-17-2009, 09:29 AM
# owners is irrelevant if it's a decent car. I would bet there are extremely few one owner 348's around!
However with a major service done in 2002 it means another belt service at minimum is now due.
You should be able to negotiate that cost in the sale.
If the car looks like a good car don't run away. You may find other cars may need more than this one!
Gcalo is offline
