Fan warning light - Ferrari Life
post #1 of 8 Old 08-03-2009, 04:46 AM Thread Starter
CRAZYHORSE's Avatar
Ferrari Life Posts: 45
Fan warning light
I have a newbie question,driving down interstate Sat morning and noticed the Fan warning light on,quick of gauges revealed temps 185-190 water and oil,all seemed ok. When i got home and went to shut down and just turned ign switch one click (not all way to off) the fans were running.Later after cool down i checked tank and level is fine.All wires connected to senders on tank. Whats the problem,sender?
Thanks in advance.
Bill
Dream as though you'll live forever,live as though you'll die tomorrow.
James Dean
CRAZYHORSE is offline
post #2 of 8 Old 08-03-2009, 12:12 PM
Ferrari Life Posts: 6,204
check the connectors as this is an older car and they can become worn, brittle etc.
check they are indeed clean.
Thinking this is minor at best...like you said..sender. Might want to swap one, keep one not connected
post #3 of 8 Old 08-03-2009, 01:00 PM Thread Starter
CRAZYHORSE's Avatar
Thanks Granucci, i was hoping someone would say minor problem or sender.Dummy me,should have said 82 308 GTSI instead of making you look it up.Again, thanks i'll check/clean if no fix,i'll replace.
Bill
James Dean
post #4 of 8 Old 08-21-2009, 06:44 PM
Neonzapper's Avatar
Ferrari Life Posts: 1,008
Are you sure it was a warning light? The reason I ask, is because whenever the fan is on, the light in the upper left dash comes on. It goes off whenever the fan is turned off. I'm not sure if that's the light you are talking about. If it is, it isn't a warning, but instead, it is a reminder that the fan is "on".
I re-read your post, and maybe you are referring to the radiator fans instead of the interior fan. If so, ignore my post
Neonzapper is offline
post #5 of 8 Old 08-23-2009, 06:19 AM Thread Starter
CRAZYHORSE's Avatar
The light i'm referring to is the orange light in the upper left corner of the dash pod.Again, don't really what it means when it's lit,(1)is it sensening the fans not running and should be (2) fans are running (2)engine hot and are running? Where is the light you're referring to,fan turned on?
Thanks for your input.
Bill
James Dean
post #6 of 8 Old 08-23-2009, 11:28 PM
Ferrari Life Posts: 15,136
Bill
On the 308 GTB I used to own, the light just indicated that the fans were on.
post #7 of 8 Old 08-24-2009, 03:22 AM Thread Starter
CRAZYHORSE's Avatar
Thanks Boxer,i guess i don't have a problem after all.
James Dean
post #8 of 8 Old 08-24-2009, 11:44 AM
Ferrari Life Posts: 3,928
It's the same on my '84 GTS Qv. If it goes off when you turn the fan off, then no problem.
Archie
archiegibbs is offline
