Possibly of some interest? - Ferrari Life
post #1 of 4 Old 04-16-2008, 08:39 PM Thread Starter
dinogt4guy's Avatar
Ferrari Life Posts: 177
I thought this was good info….Have a great day!
: FW: Get the most out of your GASOLINE!
From someone who lives in California and works in the gasoline industry:
I learned some new things....and as much as we all drive I thought this
TIPS ON PUMPING GAS I don't know what you guys are paying for
gasoline....but here in California we are also paying higher, up to $3.50 per
gallon.
But my line of work is in petroleum for about 31 years now, so here
are some tricks to get more of your money's worth for every gallon...
Here at the Kinder Morgan Pipeline where I work in San Jose , CA we
deliver about 4 million gallons in a 24-hour period thru the pipeline. One
day is diesel the next day is jet fuel, and gasoline, regular and premium
grades. We have 34-storage tanks here with a total capacity of
16,800,000 gallons.
Only buy or fill up your car or truck in the early morning when the
ground temperature is still cold. Remember that all service stations have their
storage tanks buried below ground. The colder the ground the more
dense the gasoline, when it gets warmer gasoline expands, so buying in the
afternoon or in the evening....your gallon is not exactly a gallon. In the
petroleum business, the specific gravity and the temperature of the gasoline,
diesel and jet fuel, ethanol and other petroleum products plays an important
role. A 1-degree rise in temperature is a big deal for this business. But the
service stations do not have temperature compensation at the pumps.
When you're filling up do not squeeze the trigger of the nozzle to a
fast mode. If you look you will see that the trigger has three (3)stages:
low, middle, and high. In slow mode you should be pumping on low speed,
thereby minimizing the vapors that are created while you are pumping.
All hoses at the pump have a vapor return. If you are pumping on the fast rate,
some other liquid that goes to your tank becomes vapor. Those vapors are
being sucked up and back into the underground storage tank so you're getting
less worth for your money.
One of the most important tips is to fill up when your gas tank is
HALF FULL or HALF EMPTY. The reason for this is, the more gas you have in your
tank the less air occupying its empty space. Gasoline evaporates faster
than you can imagine. Gasoline storage tanks have an internal floating roof.
This roof serves as zero clearance between the gas and the atmosphere, so
it minimizes the evaporation. Unlike service stations, here where I work, every
truck that we load is temperature compensated so that every gallon is actually the
exact amount.
Another reminder, if there is a gasoline truck pumping into the storage
tanks when you stop to buy gas, DO NOT fill up--most likely the
gasoline is being stirred up as the gas is being delivered, and you might pick up
some of the dirt that normally settles on the bottom. Hope this will help you
get the most value for your money.
DO SHARE THESE TIPS WITH OTHERS!
WHERE TO BUY USA GAS, THIS IS VERY IMPORTANT TO KNOW.
READ ON
Gas rationing in the 80's worked even though we grumbled about it. It might even be
good for us! The Saudis are boycotting American goods. We should return the
favor. An interesting thought is to boycott their GAS. Every time you fill up the car,
you can avoid putting more money into the coffers of Saudi Arabia. Just buy from
gas companies that don't import their oil from the Saudis.
Nothing is more frustrating than the feeling that every time I fill-up the tank, I am
sending my money to people who are trying to kill me, my family, and my friends.
I thought it might be interesting for you to know which oil companies
are the best to buy gas from and which major companies import Middle Eastern
oil.
These companies import Middle Eastern oil:
Shell.............................205,742,000 barrels
Chevron/Texaco.............144,332,000 barrels
Exxon /Mobil................. 130,082,000 barrels
Marathon/Speedway.......117,740,000 barrels
Amoco...........................62,231,000 barrels
Citgo gas is from South America, from a Dictator who hates Americans. If you
do the math at $30/barrel, these imports amount to over $18 BILLION! (oil is
now $90 - $100 a barrel.
Here are some large companies that do not import Middle Eastern oil:
Sunoco..................0 barrels
Conoco..................0 barrels
Sinclair..................0 barrels
BP/Phillips...............0 barrels
Hess.....................0 barrels
ARC0.....................0 barrels
If you go to http://www.sunoco.com/ you will get a list of the
station locations near you.
All of this information is available from the Department of Energy
and each is required to state where they get their oil and how much they are
importing. But to have an impact, we need to reach literally millions of gas
buyers.
It's really simple to do. Now, don't wimp out at this point.... keep reading
and I'll explain how simple it is to reach millions of people!!
I'm sending this note to about thirty people. If each of you send it
to at least ten more (30 x 10 = 300)...and those 300 send it to at least
ten more (300 x 10 = 3,000) .. and so on, by the time the message
reaches the sixth generation of people, we will have reached over
THREE MILLION consumers !!!!!!! If those three million get excited and
pass this on to ten friends each, then 30 million people will have been contacted!
If it goes one level further, you guessed it ..... THREE HUNDRED MILLION PEOPLE!!!
Again, all you have to do is send this to 10 people.
How long would all that take?
There is nothing like a Ferrari, there never has been and never will be!
dinogt4guy is offline
post #2 of 4 Old 04-16-2008, 09:02 PM
Chrishawk4's Avatar
Ferrari Life Posts: 3,874
Very interesting articles. I will definitely think about those tips when I fill up the tank! Unfortunately I frequently buy gas from speedway and shell... Pete wouldn't like it if we didn't buy from Shell
Chris
“ To accomplish great things, we must not only act, but also dream; not only plan, but also believe.”-Anatole France
"Dude, it's just math"-Pete
Chrishawk4 is offline
post #3 of 4 Old 04-17-2008, 04:31 PM
Saint Bastage's Avatar
Ferrari Life Posts: 1,839
Hey chris...I thought it was an interestingread as well. I didn't put on my thinking cap. Someone else did. check this out.
http://www.snopes.com/inboxer/household/gastips.asp
Lane
Saint Bastage is offline
post #4 of 4 Old 04-17-2008, 05:37 PM
Chrishawk4's Avatar
Very good, very good. I went to Speedway just before I logged on That was definitely an interesting read Thank you for sharing that!
Chris
