Car Washing - using a water filter - Ferrari Life
post #1 of 21 Old 05-30-2013, 11:39 AM Thread Starter
Fiorano's Avatar
Ferrari Life Posts: 4,348
Fellow F-Life member V8TDF recently commented on this thread http://www.ferrarilife.com/forums/cu...tml#post247492, that he uses a water filter when spraying down his car after washing.
Well, I was more than interested in this as I live in an area with particularly hard water and even using microfibre cloths to dry the car often does not get rid of all of the watermarks on the car - especially the black ones. And no matter how clean I keep the cloths, putting a cloth in contact with a painted surface can only result in micro scrapes over time.
The idea of simply spraying down the car, walking away and it being watermark free was just too appealing.... So I purchased the following filter system, set it up and set about testing the promises of the very friendly supplier!
Maxi-Filter - Refillable Long Life Water Filter System from More Than Polish
Here's the system in place in my 'car wash closet'!
Fiorano is offline
post #2 of 21 Old 05-30-2013, 11:42 AM Thread Starter
Fiorano's Avatar
So first things first, I tested the system out on the Range Rover. A nice big black bonnet and a (rare) sunny day in Ireland were the perfect ingredients.
Stage 1 - wash the car fully, spray off with the power hose and leave to dry naturally.
This left the following results;
Fiorano is offline
post #3 of 21 Old 05-30-2013, 11:46 AM Thread Starter
Fiorano's Avatar
Stage 2 - Repeat the entire process (much to my wife's amusement... your washing a perfectly clean car again, why...?)
This time spray down with the powerhose to remove suds etc, then rinse over with second hose connected to the water filter.
Results as follows;
Fiorano is offline
post #4 of 21 Old 05-30-2013, 11:50 AM
Ferrari Life Posts: 11,858
Barry- When I had them set up my water softener, I had it done so it softens the outside faucet, too. So I always wash the car with soft water.
You should never wash a car in the sun, especially a black one, so I assume this was merely a test of the filter.
post #5 of 21 Old 05-30-2013, 11:51 AM Thread Starter
Fiorano's Avatar
Verdict:
The system itself it not particularly cheap - will set you back approx 100 GBP, but this works the cost per wash will most probably be measured in pennies/cents so for petrolheads like us its not a significant expense at all.
The pictures give some indication of the result, but in person they are even more impressive. Literally, the car dried without a single watermark anywhere. I have since used it on both Ferrari's the other Land Rovers and the windows of the house!
If you have similar problems with water hardness and have to physically dry your cars to get them gleaming, this is a real time saver and leaves the car even better presented for less labour.
Very glad I made the purchase.
Fiorano is offline
post #6 of 21 Old 05-30-2013, 11:53 AM Thread Starter
Fiorano's Avatar
I agree Terry. Deliberately did it in the sun to highlight the watermarks in stage 1 and to test whether the filtered water would work in direct sunlight.
(That said, I'm guessing my idea of a hot, sunny day might differ significantly with your experience of the same thing! )
Fiorano is offline
post #7 of 21 Old 05-30-2013, 01:41 PM
Barry- The humidity here was 5% earlier this week and 94F/34C, so yes, quite a difference. As you wash a car here, you need to constantly hose down the rest of the car as you wash one section.
post #8 of 21 Old 05-30-2013, 01:50 PM
Italian Lover's Avatar
Ferrari Life Posts: 6,738
Barry,
w/ smiles
Jimmy
Italian Lover is online now
post #9 of 21 Old 05-30-2013, 01:54 PM
Terry, gawd ...with that kind of humidity, I can literally take shower outside and forget drying. By the way, rainy season here has started two weeks earlier than usual and probably would last for at least six weeks. Humidity ? Oh plenty and great environment for fungal business.
w/ smiles
Jimmy
post #10 of 21 Old 05-31-2013, 12:43 AM
Habsy's Avatar
Ferrari Life Posts: 795
w/ smiles
Jimmy
Jimmy you going into the mushroom growing business to fund the next car?
Cars
458 coupe normale, California T, Speciale A, 458 GT3, FF Maserati Ghibli diesel!
on way in 2015: La F, and 488, 2016 488 spider
Habsy is offline
post #11 of 21 Old 05-31-2013, 05:34 AM
amanderu's Avatar
Ferrari Life Posts: 562
Good R&D, Barry... thank you for sharing it. Is that Kercher a good one to buy for the power spray? Is it not better to connect the filter in between your kercher and the main tap?
Gus
Quit work - Get some stuff - Go somewhere - Have some fun
amanderu is offline
post #12 of 21 Old 05-31-2013, 06:06 AM
Paul, that could be a great idea !!! ...considering the market price for the top of the line Japanese mushroom "matsutake", which can easily fetch $100 per piece. (Do not ask my why this is so ).
w/ smiles
Jimmy
post #13 of 21 Old 05-31-2013, 06:17 AM
champagne612's Avatar
Ferrari Life Posts: 10,022
Barry
I am all in!
Just need to find out where to source all these products.
champagne612 is offline
post #14 of 21 Old 05-31-2013, 06:46 AM
GuyIncognito's Avatar
Ferrari Life Posts: 3,340
Originally Posted by champagne612 View Post
Barry
I am all in!
try these guys:
http://www.detailersdomain.com/
Originally Posted by rollsorferrari? View Post
Chas, you sir, are a genius.
GuyIncognito is offline
post #15 of 21 Old 05-31-2013, 01:30 PM Thread Starter
Fiorano's Avatar
Gus
The Kercher is excellent. Had it 4-5 years now, never a problem and excellent pressure. Get the right lance and snowfoam click on bottle and away u go!
The reason the filter is not attached to the pressure washer is that I only use the filtered water for the final rinse off. If I used it for the lot, i'd be changing the filter medium every week!
Fiorano is offline
post #16 of 21 Old 05-31-2013, 01:33 PM Thread Starter
Fiorano's Avatar
Barry
I am all in!
I purchased in morethanpolish.com, though they are uk based.
Fiorano is offline
post #17 of 21 Old 06-01-2013, 12:42 AM
Habsy's Avatar
w/ smiles
Jimmy
Yes I know that's why i asked and your mention of fungals lol
Long time since I was in Tokyo is it still as crazy as ever?
Cars
Habsy is offline
post #18 of 21 Old 06-01-2013, 12:54 AM
Paul, if you have been here, you would know. This place is still crazy as ever, in both extremes, if you are talking about how much things can cost.
Example: couple dozens of domestic cherries neatly packed in box as if they were jewels can cost a hundred to two US$ or like I do, go to Costco and get import for eight $.
w/ smiles
Jimmy
post #19 of 21 Old 06-01-2013, 04:33 AM
Ferrari Life Posts: 2,199
Griot's have a couple of models:
The rollaround tank style model for $370, that allows changing the media when depleted for $89: Portable Tank Style Water Deionizer
A small inline cartridge filter style for $145 where you changeout the cartridge when depleted for $125: In-Line Water Softener With Fittings
I've also seen a 2 tank type that incorporates an RO membrane either up or down stream of the deioniser to reduce the TDS to nearly 0. Can't recall who makes it ATM, however.
post #20 of 21 Old 06-01-2013, 07:16 PM
t1fosI's Avatar
Ferrari Life Posts: 1,733
These guys are very good for detailing supplies - Car Care Products | Detailing Products | UK - Clean Your Car
For Karcher, I use Chemtec based in Middlesex but mobile for national coverage.
Melvyn (the Sales Director) always seems to have the best price compared to other local competitors (and he is a nice bloke).
As an aside the Karcher that I have has the water softener built in which helps as the water here is very hard.
t1fosI is offline
