246 F1 Technical Data - Ferrari Life
post #1 of 2 Old 03-26-2014, 09:44 AM Thread Starter
monsterwrc's Avatar
Ferrari Life Posts: 10
So if you've read my earlier thread you'll know that I'm gathering data for a replica 246 I plan on building. I don't want anyone else to have to spent 2 or even more hours trying to find stuff on this car so I thought i'd post it here.
ENGINE:
FERRARI 2.4L V6
Type: front, longitudinal 65 V6
Bore/stroke: 85 x 71 mm
Unitary displacement: 402.88 cc
Total displacement: 2417.33 cc Compression ratio: 9.8 : 1
Maximum power: 206 kW (280 hp) at 8500 rpm
Power per litre: 116 hp/l
Maximum torque: ?
Valve actuation: twin overhead camshafts per bank, two valves per cylinder
Fuel feed: three Weber 42 DCN carburetors
Ignition: two spark plugs per cylinder, twin magnetos
Lubrication: dry sump
Clutch: multi-plate
TECHNICAL SPECIFICATIONS :
1958 FERRARI 246 F1
Drive: FR
Width: 1396cm
Height: 373cm
Weight:1235lbs- 575kg
Trans: 4 speed MANUAL
Chassis: Tubular Steel
Body: Aluminium
Breaks: DRUMS
Steering: Worm & Sector
Engine: 2.4L V6
Front tyres: 5.50 x 16
Rear tyres: 6.50 x 16
Hope this helped!
monsterwrc is offline
post #2 of 2 Old 03-26-2014, 09:57 AM Thread Starter
monsterwrc's Avatar
-Kevin
"If you have God on your side, everything becomes clear."
Ayrton Senna
Last edited by monsterwrc; 03-26-2014 at 10:09 AM. Reason: Don't mind this reply, the image isn't showing up...
