Cali lift or jack points - Ferrari Life
post #1 of 2 Old 08-16-2018, 07:32 AM Thread Starter
Ferrari Life Posts: 1
I think I can identify the rear lift points, a rectangular metal depression ahead of the wheel wells (photo 1). The front lift points are not so easily identified. Are they small metal protrusions with a threaded hole behind the front wheels (photo 2)? If so, is the threaded hole there to attach a special jack pad? Must the belly pan be loosened to access the jack point?
Thanks for any help on this.
1321nsr is offline
post #2 of 2 Old 02-06-2019, 11:05 AM
George Vosburgh's Avatar
Ferrari Life Posts: 30
The manual will tell you where you can jack the car up. On my 599 it's very obvious because aside from the lift points, everything else has a covering plate.
George Vosburgh is offline
