Question about Exhaust Bypass Valve Operation - Ferrari Life
post #1 of 4 Old 06-25-2014, 08:30 AM Thread Starter
bisel's Avatar
Ferrari Life Posts: 419
This may have been asked before, but I have not been able to find this specific information.
With respect to the Exhaust Bypass Valves, can anyone answer the following:
What is the default state of the exhaust bypass valves (engine off, no vacuum to the valves)? Are they open or closed? (On the 360 and F430, they are open)
I assume the initial state of the valves when you start the engine and vacuum is available to the bypass valves is that they are closed. At engine idle, if you disconnect the electrical connector at the vacuum solenoid valve, will the valves open or remain closed? (On the 360 and F430, they will open)
I am trying to determine if the 458 is the same as the 360/F430. Thanks for any help you can give me.
Kind regards,
bisel is offline
post #2 of 4 Old 06-25-2014, 10:24 AM
Ferrari Life Posts: 11,856
Steve- 360 bypass valves are fail open, which means with no vacuum, they will eventually open when the engine is shut off. Residual vacuum may keep them closed for a while. On a 360 to keep them open all the time, the vacuum hose ends to the pneumatic valves are removed and the hose ends plugged.
Maranellos are the opposite.
post #3 of 4 Old 06-25-2014, 11:08 AM Thread Starter
bisel's Avatar
Thanks, Terry. Do you happen to know if the 458 is more like the 360 or more like the 550/575?
Regards,
bisel is offline
post #4 of 4 Old 06-25-2014, 02:30 PM
Steve- More like the 360/F430.
