TR Alternator belt Issues?
Old 05-22-2009, 10:08 AM   #1
barabus's Avatar
Ferrari Life Posts: 24
Default TR Alternator belt Issues?
My Testa has thrown a belt months ago, i replaced it and that one started fraying. It was time for my cam belt service so i told him about the alt belt. He said the pulley seems slightly out of allignment so he re-alligned it. Half way home from the service garage as i applied some heavy right foot it shot off again. Had the car traillered back to garage the tech will look into the problem but can't think what can be wrong? Any ideas why it should be throwing belts?
Another problem while i'm at it was the tuning was way out on the left bank he could'nt set it correctly while the right bank was spot on, as i'd just replaced all 12 injectors he said it must be the metering head, does this sound right?
Now he's got the car back he'll take off the metering heads and send them away for cleaning and i hope that solves that problem?
So that's me Carlos again.
barabus is offline   Reply With Quote
Old 05-22-2009, 10:29 AM   #2
Ferrari Life Posts: 5,053
MY mind: has to be alignment or tensioner. Need a serious look, you seem to be getting lucky. Fraying means only to me there is something messin with it, so if you can open that baby up and rev while in the shop, might see it.
r
Old 05-22-2009, 11:06 AM   #3
Ferrari Life Posts: 12,793
Could the alternator be flexing on its mounts?
Also is the right spec belt fitted. Had a similar problem a few years ago when Ferrari sourced the wrong spec belt and it kept jumping whenever I accelerated hard.
Boxer
Old 05-22-2009, 12:16 PM   #4
barabus's Avatar
r
While the engine was out techy put a straight edge on the pulleys' there was a slight way out and he rectified it, or so he thought?
Dayco belt supplied by Maranello UK. Bolted down good and proper so not flexing. However it is not the original alternator, a new one was fitted when the regulator went bust and could'nt find a replacement. This belt was OK until i accelerated hard.
Old 05-22-2009, 11:15 PM   #5
Something is flexing under load and causing the belt to pop. DO you still have the older frayed belt? If so can you compare the inner grooves to the new one.
Boxer
Old 05-23-2009, 07:02 AM   #6
Ferrari Life Posts: 303
It's possible that the crankshaft and alternator pulleys could be mis-matched, meaning different groove dimensions and shapes? I do recall that some years ago that other TR owners had this issue, and they changed the alternator pulley to fix it.
The stock TR alternator mounts snugly into the left side cambelt cover, and there is practically no room for misalignment. Since you have a different alternator, it's very possible there are still alignment issues with the crankshaft pulley. Does your TR have a Bosch or a GM alternator?
Also be sure the correct tension is applied to the belt, a "rule of thumb" is that you should be able to "wobble" the belt back and forth about 1/2 inch to maybe 3/4 inch when it's tight, does this make sense?
Old 05-23-2009, 08:20 AM   #7
Ferrari Life Posts: 3,613
Originally Posted by carguy View Post
It's possible that the crankshaft and alternator pulleys could be mis-matched, meaning different groove dimensions and shapes? ---
That's a great point.
You may have an incorrect alternator pulley.
Old 05-23-2009, 12:24 PM   #8
barabus's Avatar
It's an AC Delco replacement alternator and the original pulley was put back on. The belt tension was applied by my mechanic so he should know the correct tension. He was thinking that maybe there's a lip on one side of the pulley and that it could have possibly been put on the wrong way, is this possible?
Old 10-22-2011, 12:42 PM   #9
Default Use The aged spare Belt.....
Had The Problem frequently, just as described....when I changed the Service garage, they told me, One should use The "aged" spare part that's in the toolbox of The Car....since then it Never came up again.....don't ASK me why?....
Stkes is offline   Reply With Quote
Old 10-22-2011, 12:53 PM   #10
An overtightened belt can do a lot of damage.
Maybe that was issue?
Old 10-26-2011, 03:34 AM   #11
Petervg1's Avatar
Ferrari Life Posts: 40
His Ferrari Service Bulletin might help: http://ferrari.cdyn.com/service_bulletins/sb10-19.pdf
Petervg1 is offline   Reply With Quote
Old 10-26-2011, 11:20 AM   #12
Ferrari Life Posts: 3,610
Peter- That is a pretty nice website, thanks. Especially handy for owners of older cars.
Old 10-26-2011, 12:37 PM   #13
Petervg1's Avatar
You're welcome Terry :-)
Old 10-26-2011, 01:21 PM   #14
Ferrari Life Posts: 6,603
great post!
Everything you know is wrong
Old 10-26-2011, 03:56 PM   #15
Default my take, my stab.
welcome to the site.
However, I will take a bit of exception to the belt in the toolbox as it's for display only IMO unless you knew it's age and condition.
Age and condition is a key factor in some failures, too. I suspect they used that belt as the replacement one was incorrect and/or after replacing the belt, again, got it right in the adjustment/alignment: May never know.
Correct belt, fresh one off the shelf is key. RICAMBI IIRC threw out a bit of dated parts just for the expire reason...more likely the age would have some not only suspect, but could make one a bit liable.
I know this can start the endless belt discussion, but having fresh correct belts is better than an old one or one where the history is unknown.
2cents.
Old 10-26-2011, 04:33 PM   #16
Ferrari Life Posts: 859
2cents.
Exactly correct.
The single V belt was a stupid idea for a 125 amp alternator and was a source of constant trouble. Ferrari abandoned it early on and offered a retrofit kit mentioned above.
The standard V belt needed to be so tight to be reliable it really overstresses the bearings in the alternator.
Ferrari only offers retrofit kits when they know and cannot deny they really stepped in it.
That was only one of 5 TSB's on the issue of Testarossa alternator belts by the way if that tells you anything.
Ferrari Life » Ferrari Forum » Ferrari Owners » TRs: Testarossa - F512M » TR Alternator belt Issues?
