| Owner Join Date: Jun 2011
Ferrari Life Posts: 5
Has anyone found a scanner that will work with 512tr that does'nt cost the amount of a major?
Ferrari Life Posts: 3,609
Don- Unless I am mistaken, there is no OBD II connector on the 512 TR. The engine is controlled by a Motronic 2.7 system, and factory testers like the SD1 could only analyze the engine Motronic ECU functions. There is a diagnosis plug near the ECUs, but I think it is proprietary for the factory SD1 tool. Leonardo's tool will work, but it is $20K or so. Maybe Brian can elaborate or correct. Taz Terry Phillips Present: 575M 135171 Past: Dino 246 GT 02984, 365 GTB/4 14009, 308 GTS 25125 Every day I look around, and if nobody is shooting at me, it is a pretty good day. |
Yep your rite about that. I was hoping someone new of possibly being an sd1 to obd adapter. Wishful thinking
Ferrari Life Posts: 13
Take a look on the Texa tool.....it's called IDC4. Let me know if you need more info.
Gerdi- How about doing a dedicated thread to the Texa tools and what they can do on a Ferrari? Do not think Andrew will mind because a working tool would benefit all of us. Might end up with another Ferrari Life sponsor, too. Their website is too generic to tell me much. Taz Terry Phillips Present: 575M 135171 Past: Dino 246 GT 02984, 365 GTB/4 14009, 308 GTS 25125 Every day I look around, and if nobody is shooting at me, it is a pretty good day. |
Yes PIS reset is possible. Take a look at the pictures. Also you can see the system which are possiple to do a diagnosis. If you detailed information, write me a PM with your email adress. |
You need a 55 pin break-out box or Autoforce tester with 55 pin and some have ABS built-in. I brought mine back in 91 for 13,000 US dollars. I have seen on EBAY from 500-2000 $. Make sure it comes with a 55 pin connector and books with tech info. John Bradley also put-out a book with pin info for the early Motronic systems.
