Water pump....change or not???
Old 10-31-2011, 05:36 PM   #1
Ferrari Life Posts: 48
Default Water pump....change or not???
So we're doing the major on my TR. Car has 13k miles. My mechanic told me the last time he did a rebuild kit it leaked and he had a lot of issues getting it to seal. The pump on the car isn't leaking...seems he's more inclined to leave it on rather than mess with it. Thoughts??
Thanks!!
TRChad is offline   Reply With Quote
Old 10-31-2011, 05:51 PM   #2
Ferrari Life Posts: 6,603
do it.
Everything you know is wrong
Old 10-31-2011, 05:57 PM   #3
barcheta's Avatar
Ferrari Life Posts: 1,394
+1... its not that much money and is piece of mind.
Current: 85' GTS QV
"I don't sell cars, I sell engines. The cars I throw in for free since something has to hold the engine."
barcheta is online now   Reply With Quote
Old 10-31-2011, 06:50 PM   #4
Is there a particular rebuild kit that works better?
Old 10-31-2011, 06:55 PM   #5
Ferrari Life Posts: 3,609
Default Brian, TR Water Pump?
Chad- Give Daniel at Ricambi a call and get his recommendation.
If you are really lucky, Brian Crall will also chime in on the answer.
Old 10-31-2011, 10:57 PM   #6
Ferrari Life Posts: 12,793
I would do it.
If you don't and it goes bad, it is an engine out job to get to it again.
Boxer
Old 11-01-2011, 06:04 AM   #7
Petervg1's Avatar
Ferrari Life Posts: 40
I am currently doing a 30k service on my TR and I change all seals and bearings. It's not that much money extra (+/- $100) and I don't want to pull the engine out in the next 5 years.
Petervg1 is offline   Reply With Quote
Old 11-01-2011, 06:35 AM   #8
Ferrari Life Posts: 859
If he feels sqeemish about a waterpump he has no business doing a major.
It should be updated/modified to take the 355/550 seal anyway.
I have very strong opinions on who to select to work on these cars based on a few decades of seeing them butchered and I have serious reservations about anyone who shys away from the Ferrari equivalent of changing socks or fails to grasp the need to do so.
Old 11-01-2011, 07:09 AM   #9
Saint Bastage's Avatar
Ferrari Life Posts: 1,680
Why is this a question? Is it a financial thing or is there some schedule/time issue involved?
Just re-read and saw where there was a history of leaks after a rebuild. I've never met your mechanic and don't know who he is but my first question would be "why did the last rebuild fail?". Was there some problem with your water pump/rebuild kit or was there an issue with the way it was rebuilt? Being afraid to replace bearings and seals because of a problem in the past seems odd.
Lane
348ts SS #64, Nero on Nero
Old 11-01-2011, 07:27 AM   #10
well said and to the point as always. I am constantly amazed at people's need to believe. Need to believe they can get it done cheaper/faster. You can tell them their mechanic has little knowledge or experience on these cars, hell you can demonstrate it, and if the price is lower, even by a little bit they WANT to believe. They don't need to be talked into it. My other pet peeve is the people that take it to the dealer out of some belief that they have some magic pixie dust that the manufacturer only sells to them.
here is a tip for everyone looking for a ferrari mechanic. If you go in the shop and all the mechanics look like they are under 21----THEY ARE!!! and everything that implies.
OP this is a general rant and not directed at you. i have no knowledge of you, your car or your mechanic. Wait, i do know a little about your mechanic...
ps. would love to have seen the unedited brian post
Old 11-01-2011, 07:38 AM   #11
just had a thought. if everybody took their cars to quality places like brian's and richard and fernando's, they would have to expand and train new mechanics the right way. how would that be?
Old 11-01-2011, 12:15 PM   #12
Guys I appreciate the help. Let me make one thing clear...the decision to potentially "not" do this has NOTHING to do with finances. I think we can all agree, when you're talking about a 30K major....a pump is peanuts. It's all peanuts except for the clutch, throw out bearing. flywheel etc. The reason I'm not considering doing this is because a new one is no longer available....he claims that the pump...once removed...is sometimes diffacult to get to seat right and often times leaks. It's not leaking a drop now. He claims it might be best not to mess with it. Something about a friction seal. Also, if I'm going to do the rebuild kit it might be best to send the pump off to a machine shop and have it all redone???? This is all new to me. So far, we are doing belts, seals, tensioners, clutch, starter etc. The works.
Old 11-01-2011, 12:22 PM   #13
Chad- Personally, I would find someone who is not afraid of a water pump leak after a rebuild. Brian says using an updated seal will fix the problem, and if your mechanic does not already know that trick, it might be better to find someone who does.
Old 11-01-2011, 12:42 PM   #14
Ferrari Life Posts: 477
Even if the pump is not currently leaking and the car has low mileage, the effects coolant and water have on the pump internals over the many years is a real concern. There is no easy solution if the pump fails after the fact, replacing it without pulling the engine is a total nightmare...so it needs to get pulled again.
The complications that may be encountered now will be much less of an issue than the complications in a year or two when the pump does become a problem. Everything on these older cars require additional time and effort to get right, As long as you the client understands it "take what it takes" to do the job right leaving things be is a poor solution.
A couple years ago I did a major on a TR that "just had a major", yet puked coolant and oil everywhere. Once the water pump was taken apart it appeared as though it actually had never been cleaned up and rebuilt. The internal parts were completely rusted together an non-usable.
Picking and choosing items on an engine out service is a gamble I don't like to take.
Exotic Car Specialties
201 Davis Dr. Suite L
Sterling, VA 20164
703.421.5356
Old 11-01-2011, 12:46 PM   #15
New pumps were never available per se. The pump is an integral part of the motor. It just needs to be diasassembled, cleaned up and 2 seals installed. SOP on Ferrari 12 cylinder motors since the very early days.
Old 11-03-2011, 01:28 AM   #16
Petervg1's Avatar
Default Water pump parts
I just purchased the seals and bearings for my '87 TR waterpump.
These are the parts that I'll replace:
  • 101023 Seal
  • 120948 Seal
  • 121553 Seal
  • 121165 Seal
  • 133899 Bearing (2x)
  • 152051 Backplate
I guess you can call that a major for the waterpump
Also, because you have to take off the waterpump housing, you should replace the housing gasket which is:
  • 134947 Gasket
I bought the water pump seal kit from Superformance and the rest of the parts from Eurospares (Eurospares could not supply the most important seal 120948). Total cost was 77 pounds which is about $125.
And..., if a mechanic knows what he is doing, he should not be afraid to replace parts, even not when it's a Ferrari.
Ferrari Life » Ferrari Forum » Ferrari Owners » TRs: Testarossa - F512M » Water pump....change or not???
