Searching for 355
Old 01-30-2012, 07:18 PM   #41
HeelToe's Avatar
Ferrari Life Posts: 11
Originally Posted by 355dreamer View Post
No. You are totally correct to exclude the other models. The benefits of the 95s, asides from the OBD1, are numerous.
I know, I've owned 2!
I know about the motronic 2.7, dual MAP sensors and the above mentioned ability to delete the air injection pump and plumbing. Is there mooore?
HeelToe is offline   Reply With Quote
Old 01-31-2012, 03:12 AM   #42
Sandy Eggo's Avatar
Ferrari Life Posts: 345
That's about it - don't forget the unique airbox plumbing on the 95 which involves no "merging" just straight thru efficiency.
There's no real downside to a 95, if you can find one in good shape then snap it up. Some will caution you about valve guides and headers and while this is true it is also true to varying degrees with the other model years.
Sandy Eggo is online now   Reply With Quote
Old 01-31-2012, 04:07 AM   #43
355dreamer's Avatar
Ferrari Life Posts: 693
Also, no crazy factory alarm system that can leave you stranded. A better air intake routing that goes behind the C panel, vs. over the radiators as with the later years.
There's more, but I can't remember them all at the moment. All cars are prone to header failures, and while the later cars are less likely to have valve guide issues (mid 98 and above) they can still fail. I've personally seen late 99s with bronze guides that failed.
Everything you have heard is true.
355dreamer is online now   Reply With Quote
Old 01-31-2012, 05:48 AM   #44
HeelToe's Avatar
That confirms what I've gathered thus far from lurking around here for a bit. Thank you for the info.
Hopefully I'll be able to contribute something useful myself someday soon.
