Ferrari Life Posts: 1
I seem to have the opposite problem shifting into second gear on my 308 GTSI. When cold, I can shift into second beautifully. Although, as soon as the car begins to warm, 2nd gear is impossible without grinding. I've tried Redline gear oil with no results. Any ideas where I should begin?
| Owner Elite Member Join Date: Jun 2008 Location: Three forks, MT,USA
Ferrari Life Posts: 90
Sir- While I'm no expert, I'd think worn, syncro. Good test- does it shift into 2nd cleanly with double clutch? If so, then time to rebuild/replace tranny. Good luck, bill |
| Owner Elite Member Join Date: Jun 2011
Ferrari Life Posts: 442
im also,,,no expert,,,but the clutch may need to be adjusted,,,i use shell full synthetic gear oil in my 328,,,but like the other fellow posted,,sounds like the 2nd gear synchro is bad,,,although,,,i have never heard of 2nd gear being ok when cold,,,and then not ok when warm,,,anyways,,,someone on here will know exactly whats goin on,,good luck,,Brett
Ferrari Life Posts: 3,606
Dinos and cold 308s often use a 1-3 shift strategy. Will work for you until you can address the problem. Some Redline oils are too slippery for 308 transaxles and will cause the synchro rings to be too slick to do their job, which requires friction to match revs. This sounds more like your problem than a worn synchro ring or you would be getting a real crunch going into second when cold. Not sure which Redline you used, but do some research and make sure you are using the correct one. I am running Valvoline full synthetic 75W-90 in my car. Taz Terry Phillips Present: 575M 135171 Past: Dino 246 GT 02984, 365 GTB/4 14009, 308 GTS 25125 Every day I look around, and if nobody is shooting at me, it is a pretty good day. |
