Spark plugs
Old 08-03-2011, 04:09 PM   #1
XXG
Ferrari Life Posts: 14
Default Spark plugs
I have 3 FERRARIS what brand & # of plugs should I use on 1984/308 euro
thanks
XXG is offline   Reply With Quote
Old 08-03-2011, 04:13 PM   #2
Ferrari Life Posts: 5,053
By number I'm sure it's the part number, not number of plugs. You'll get an answer soon, not my area.
and
WELCOME!
Old 08-03-2011, 04:30 PM   #3
XXG
I like that spark plug # & brand ok
thanks
Old 08-04-2011, 08:02 AM   #4
ferraripilot's Avatar
Ferrari Life Posts: 340
NGK BP7ES (non resistor type) or BPR7ES (resistor type) if you run it fairly hard. If not then go with BP6ES or BPR6ES
ferraripilot is offline   Reply With Quote
Old 08-04-2011, 12:02 PM   #5
XXG
Default Ngk
how about this other NGK was also recomended
just put in today that was also recomended! NGK IRIDIUM BPR6EIX
now if I can only sell ONE of my 3 FERRARIS I'll be a happy camper thanks
Old 08-04-2011, 03:24 PM   #6
Andrew's Avatar
Ferrari Life Posts: 6,188
The IRIDIUM should work well, stronger spark and life from what I'm told. All depends on the power of the coils sending the spark too though. For a 308 might not get too much extra benefit.
Andrew is offline   Reply With Quote
Old 08-04-2011, 03:53 PM   #7
Ferrari Life Posts: 737
As Andrew said, Iridiums are great plugs but only if your car has a high energy ignition. Their stock gap is usually larger than older style copper core plugs, so if the rest of your ignition isn't up to snuff, you may have a rough running car.
Probably why Ferraripilot recommended more standard type NGK's for you.
I sure wouldn't try to run Iridiums on an older car with a conventional coil and distributor setup.
Old 08-04-2011, 04:10 PM   #8
XXG
Default ok
thats good to know, will take her out tomorrow for a run lets see what happens, paid $50:nothing else available today/he will take them back
