| Owner Elite Member Join Date: Nov 2010 Location: Gy mpieAustralia
Ferrari Life Posts: 14
Folks I'm in the market for a 308, preferably a QV. Does the standard engine tolerate unleaded fuel, or do the valve seats need to be replaced? I need to know so I can check out whether a potential purchase is OK or needs work Your comments would be appreciated thanks Bernie |
| Owner Elite Member Join Date: Jun 2011
Ferrari Life Posts: 442
my friend has an 85 QV and uses 91 octane unleaded..as well as i ., in my 328,,,,here in CA,,,its a shame that the oil companies dont let us have 92 - 93 -94 octane..like i can get in Ct...where i grew up anyways i have not heard of any issues with unleaded fuel and the 3x8 s....i have a test pipe instead of a cat...so when im up in LA,,,there is a petrol station that sells 108 octane,,,and so i try and stuff in a half a tank of that,,,car runs noticably better,,,Brett
| Owner Elite Member Join Date: Jun 2008 Location: Three forks, MT,USA
Ferrari Life Posts: 90
Bernie- Unleaded gas is required for catalytics- lead ruins them but lead acts as a lubricator/ coolant to top end of engine. In the US cars started having cats in mid '70s and by ~1980 all passenger cars where cat/unleaded. I recall up to mid '80s going to gas station and could still get leaded gas for my old cars. When leaded gas became the only available, one had to do a head job on old motors to install hardened valve seats and better valves(typically sodium filled) and run unleaded in non-cat cars. I have a 1978 308 that was originally sold in California, had cats and was spec'ed for unleaded. I've had it apart and confirmed this. Says so on dash too. I don't know when other cars where changed but the gist I understand is- if it had cats, it's had the upgrade to run unleaded. if no cats then would need up grade or run a lead additive- If such available in OZ? To the best of my knowledge these cars all require Premium gas. I'd guess a QV would have cats but am unsure of world market. Bill (Sorry so wordy) |
| Owner Elite Member Join Date: Apr 2011 Location: Canada
Ferrari Life Posts: 426
So what about carbed no cats? Safe to assume that 91-94 should be sufficient enough, or is an additive needed?
| Owner Join Date: Jan 2009 Location: D.C./Manila
Ferrari Life Posts: 974
I don't know the answer about carbed. My 308 QV (all QV being fuel injected) had been federalized with "Unleaded Only" stickers on the gas door and dashboard. Squeeze the fuel hose with your hand (under left rear tire) and check for soft spots as well as smell. If you want to replace it, Scuderia Rampante Ferrari has hoses that will withstand the E85 fuel used today. |
| | #6 | |
carbed w/no cat(original)= leaded fuel. also to best of my knowledge this would be pre ~1980. Anything that has been approved/upgraded to run unleaded must not use a lead additive. The ethanol mix is a whole nother can of worms, bill | |
thanks Bill. I have read both sides to the lead additive argument, appreciate the feedback. Brett |
Ferrari Life Posts: 12,793
For my old 308 GTB, I always used the highest octane unleaded I could find and then added lead substitute to the tank. Never had an issue with pinging.
| | #9 | |
I'd prefer to use the best fuel i can buy and avoid additives if I know this will do the trick, but will buy additives if it is a must. Thank you for feedback. | |
| | #10 |
| It was done on advice from the mechanic who had been servicing the car.
| | #11 |
which additive did you use?
| | #12 |
| Redex. Picked it up at the local car supply store.
| | #13 |
| Owner Elite Member Join Date: Aug 2007 Location: Amsterdam
Ferrari Life Posts: 638
| | #14 |
| Owner Elite Member Join Date: Oct 2007 Location: Europe
Ferrari Life Posts: 2,288
| Here we get 100 Octane fuel on Shell gaz stations. My mechanic told me not to use that high octane for "D" but rather 98 as max Octane and use lead additive only from time to time.
| | #15 |
| | #16 |
| Owner Join Date: Mar 2003
Ferrari Life Posts: 39
I usually run 89 but have also run 87 and 91 in my carb no cat 77. Doesn't seem to make any difference in performance. I don't know if it gives me a difference in gas mileage because I usually don't check it. Some say with a compression ratio of 9:1 you don't need anything better the 87 octane.
| | #17 | |
| | #18 |
Over 3000 miles now in 8 days, all on Shell V-Power (90 to 93 octane depending on the station, no ethanol). Runs like a charm, 18.2 MPG
| | #19 |
| | #20 |
| Do the stickers look to be original ex-factory or from a later conversion?
