Ferrari Life Posts: 3,257
I've started to look around to get a feel for the market for a 308 GTS. Still leaning towards an early carb model. GBP £25 - 30K seems to be asking prices at present (in the UK - my most likely market) - though what this equates to in terms of actual prices paid is yet to be discovered. It will be a couple of months before I'm in a position to buy, and I'm in no hurry so will happily wait for the right car. At present I think that the right car will be a Rosso Corsa, Crema/Tan interior, 308 GTS (as original as possible) and with all the usual history, condition, PPI checked out etc. Here's one that recently went up on pistonheads.co.uk in the UK that caught my eye. All comments welcome. Ferrari : All Original 308 GTS Barry Ferrari's: 360 Modena F1, 308 GT4 Other Italians: Ducati 916, Ducati 848 DD's: RR Sport, BMW 645ci, BMW 1200GS Adv. |
Ferrari Life Posts: 4,289
The carb'd ones are lovely, that noise they make is great. But the QV is also a great choice and performance-wise pretty much the same, don't discard it if you run into a good one. Onno |
| Owner Elite Member Join Date: Dec 2009 Location: Switzerland
Ferrari Life Posts: 1,023
The one on the picture doesn't have a drysump lubrication system. Since you have the time and like the carbed 308, look for a drysump car. Just my humble opinion. Salve, Capo ![]() The bad news: Time flies The good news: I'm the pilot You cannot make life longer but you can make it wider and also much higher. |
Ferrari Life Posts: 6,603
be different and get a GTB!
Ferrari Life Posts: 12,793
| +1, dry sump, and carbs are the way to go.
| I would if my 360 was a spider, but its not, and I've got the urge for the wind in my hair.... Barry Ferrari's: 360 Modena F1, 308 GT4 Other Italians: Ducati 916, Ducati 848 DD's: RR Sport, BMW 645ci, BMW 1200GS Adv. |
| Excuse my ignorance, but can anyone do a quick explanation of the differences between the 2 and the pros vs. cons for wet/dry sump?
| | #8 | |
There are two major advantages with a dry sump: 1. The engine can be fitted much lower in the chassis as there is no wet sump underneith. The engine being the single most heavy part of a car means you get a substantially lower centre of gravity. 2. The oil completely exits the engine after a full lubrication cycle which provides for a lesser job to cool the oil. Given these advantages, the dry sump solution is the preferred way to go for racing purposes and for car makers with a high ambition of performance. If you are going to track the car you are clearly better off with a dry sump. It is also a nice feeling when all the engineering of your car is made with performance in mind. In general, if you track a sports car with wet sump lubrication you must make sure there are centrifugal bulkheads in the sump. Salve, Capo ![]() The bad news: Time flies The good news: I'm the pilot You cannot make life longer but you can make it wider and also much higher. | |
| | #9 | |
Barry Ferrari's: 360 Modena F1, 308 GT4 Other Italians: Ducati 916, Ducati 848 DD's: RR Sport, BMW 645ci, BMW 1200GS Adv. | |
| | #10 | |
It certainly isn't the case for the 512BB (dry sump) vs the 365BB (wet sump). Apart from the cooling issue, dry sump also has the advantage of not risking oil starvation in high g-force corners. This is the main reason the 512BB went to dry sump, in my understanding. Onno | |
| | #11 | |
I believe it would make no difference on a boxer since the gear box sits under the engine anyway so the engine is going to sit high with or without a wet sump. Centrifugal bulkheads in the sump nullify the risk of wet sump cornering starvation of oil supply. Salve, Capo ![]() The bad news: Time flies The good news: I'm the pilot You cannot make life longer but you can make it wider and also much higher. | |
| | #12 | |
Ferrari Life Posts: 2,408
The wet sump 308s do have baffles in the sump but they aren't completely effective and oil starvation is a common complaint in heavy track use, particularly when slicks are being used. There is an aftermarket baffle enhancement that many are happy with, but still, for serious track use even this fails to maintain oil pressure. This is all a complete non-issue for street or even mild track use though, and skipping the drysump requirement is a good way to cut the purchase price if the plan is to drive on the street IMO. | |
| | #13 |
| Owner Elite Member Join Date: Aug 2007 Location: Amsterdam
Ferrari Life Posts: 638
To the best of my knowledge all GTS' had the wet sump whereas all Euro and UK GTB's with carbs had the dry sump. US and Australian GTB's with carbs had the wet sump. All went wet sump with the advent of fuel injection. So if you want dry sump, Barry, go UK or Euro GTB with carbs... |
