308 gearbox overheat?
Old 03-07-2010, 10:50 AM   #1
TheITGuy's Avatar
Ferrari Life Posts: 36
Default 308 gearbox overheat?
(Archie, cover your ears)
Hi folks,
I took my new baby out for a rip this evening, as I've done many times in the past couple of weeks. The roads were twisty and hilly, so plenty of gearchanging going on. She's never missed a beat on previous runs but midway through today's run, it suddenly became very difficult to engage any gear except 4th and 5th. The shift action felt wrong; taking much more effort than normal and when it DID go in (especially to third) it didn't feel like it had gone in properly- the positivity wasn't there.
I pulled in and let the car cool down for a few minutes, and 2nd and 3rd started behaving more normally. First and (especially) reverse are still giving gyp, though.
I'll go and check how they're behaving when the car's cooled down some more, but I was wondering if anyone else had encountered this behaviour? Could it be that the gearbox oil overheated? There are no drips from the car, so it is highly unlikely to be low on gearbox oil.
The engine's temperatures and oil pressure remained rock-solid as usual throughout. The workout wasn't THAT punishing, so I'd be surprised if it was due to the 'box overheating, but I can't think what else it could be due to.
Any advice very welcome!
Oh, and somebody tell Archie he can uncover his ears now
People often accuse me of thinking the entire world revolves around me. It doesn't. It revolves around the SUN... which shines out of my ar$e.
TheITGuy is offline   Reply With Quote
Old 03-07-2010, 11:46 AM   #2
Ferrari Life Posts: 90
Did the clutch feel normal or did it seem to not disengage or slip? By your description it sounds like trans but I've never seen one do this while hot- many times while oil cold. Do you have a non-contact infra red thermometer?(available at autoparts stores for around $50.00 here) Maybe drive and see if trans gets hotter than engine (it shouldn't).
bill ward is online now   Reply With Quote
Old 03-07-2010, 12:26 PM   #3
Ferrari Life Posts: 3,613
Better get some Redline oil in that gearbox before you toast the synchros!
Old 03-07-2010, 08:52 PM   #4
SCM246's Avatar
Ferrari Life Posts: 311
+1
I would definitely check the fluid level as a first precaution
Either of these are preferred oils in the Dino gearbox, 308 may be the same.
Redline 75-90W NS
or
Swepco 201
SCM246 is offline   Reply With Quote
Old 03-07-2010, 10:21 PM   #5
Ferrari Life Posts: 12,792
Never heard of that happening on a 308. Changing the gearbox oil definitely a good place to start.
Boxer
Old 03-24-2010, 08:59 PM   #6
So what was the final outcome of this overheat issue?
Old 07-14-2010, 07:47 AM   #7
TheITGuy's Avatar
Leaving the car (and indeed the country) for three months seemed to do the trick....
It only happened that one time, I'm not even sure it WAS an overheat to tell you the truth. All I know is that it became difficult to change gear on that trip. I've driven it plenty of times since then, just as hard and for longer durations and it's never put a foot wrong. I put it down to Miscellaneous Weirdness but I'll change the gearbox oil to that Redline stuff the lads mentioned when I'm doing the oil and filter change next week.
As far as I remember, the clutch felt fine, no slipping while driving and no making the car creep forward when sitting in gear with the pedal depressed.
Sorry for the delay in replying, and thanks to all for your help!
Old 07-14-2010, 10:21 AM   #8
TheITGuy's Avatar
By the way, if any UK readers are trying to figure out where they can buy Redline 75W90NS gearbox oil by the gallon, I ordered mine at http://www.lkperformance.co.uk . Redline's website had a big long list of resellers, but all the ones I clicked on prior to LK Performance only sold it by the quart. Mind you, four quarts cost exactly the same as one gallon but I hate to see wasted packaging.
