| Owner Join Date: May 2008 Location: Brisbane, Australia
Ferrari Life Posts: 72
Hi All, Had my 308GTB out today and got caught in a rain shower. With the wipers on the first speed, they work normally for about 5 strokes and then have a 'rest' for a second or so, followed by a click and another 3 or 4 strokes. This keeps going in this pattern. On second speed, they work normally. I don't think vetro's had intermittent wipers as standard so am wondering if its a sticky relay or similar. Any ideas appreciated. Kon |
| Owner Elite Member Join Date: Jun 2008 Location: Three forks, MT,USA
Ferrari Life Posts: 90
Kon- I'll bet you that the linkage from wiper motor to wiper has a broken or loose joint. Think of a rotating cam that slips sometimes and catches sometimes. other possibility is worn wiper motor but I would not expect that. good luck and please let us know what it was when you find it. Bill |
| | #3 | |
Hi Bill Had a look at the linkage today after removing the trim around the spare tyre. I sprayed the two ball joints (?) under the wipers with penetrating fluid which made a big difference. Tested by lifting up the wipers to the off windscreen position and turning them on. The more they ran the looser they got. Hopefully thats a fix - thanks very much for the suggestion. Usually when I go out I turn on and run everything - aircon, headlights, windows, horn, to keep it all loose and working. I forgot all about the wipers though. Maybe I should run them when I wash the car to make sure they dont tighten up Kon | |
I wounder if the nut that attaches the wiper motor to cam that moves arm is loose or maybe 'owled' out a little. Maybe the click you're hearing is allowable slippage when arm binds or possibly loose? Do you get alot of dust there? I live on a gravel road so I try to use graphite or other lubes that don't attract dust as much on linkages like this. Bill
| Owner Join Date: Mar 2003
Ferrari Life Posts: 39
On my 77 the stalk lever in the up position is for intermittent wipers and in the down position it is regular wipers speed (slow speed). There is a high speed switch on the console for faster operation. Oh I have only used my wipers twice in the 10 years I have owned the car. I don't take it out in the rain. I do run all of the electronics as a habit when I ride.
