Buying missing parts, need advice
Old 02-17-2010, 10:19 AM   #1
Arturin's Avatar
Ferrari Life Posts: 26
Default Buying missing parts, need advice
Hi gentlemen,
Now that I have the car and having to wait at least one month for the mechanic to have time to make the major service to the 355, I´m in the search of missing parts.
Apparently when the last major service was done, the people who did it forgot to put the timing covers in place And i guess they decided that taking everthing apart again just to put them wasn´t worth.
Now Im going to buy those parts.
I`m going to buy the 28 and 22 parts of the diagram along with their respective bolts. But, what are 29 and 23??? it says that its a protection but is it really necessary or can I just put the timing guards and not these pieces?
Another thing, there are two types of guards the 3 bolt old ones and the revised 5 bolt. Will there be any problem if i put the 3 bolt old ones? Or is there something wrong with them and should be changed for the 5 bolt?
thanks
Arturin is offline   Reply With Quote
Old 02-17-2010, 01:50 PM   #2
Ferrari Life Posts: 6,603
Originally Posted by Arturin View Post
Hi gentlemen,
omg. How can you miss that! I would definitely recommend replacing them. Pretty unbelievable. Hopefully you can tell us the name of that shop so none of us will go there.
If you got the car a PPI please let us know who did that as well.
I would advise putting all parts back on including the updated ones. have a competent mechanic do it.
Old 02-17-2010, 03:13 PM   #3
Arturin's Avatar
The people who will service my car know what theyre doing. They are the ones who service all these type of cars in the middle-north area of Spain and theyre just 5 miles away from my home (Lucky me! ) If its a strange/exotic car take it to them. The other day when I went to talk to them they were servicing a group B Ford rs200 and a lambo diablo...
Just a stupid question I have( Don´t want to flood the forum with new threads with my stupid questions):
The knob on the speedo gauge is to reset the partial milleage,so far so good. But what the hell is the function of the knob in the rev gauge???
Old 02-17-2010, 03:37 PM   #4
Dude, don't ever touch that one!!!!
Old 02-17-2010, 10:11 PM   #5
Ferrari Life Posts: 12,792
You should be able to get all the parts you need from Eurospares int eh UK.
Boxer
Old 02-18-2010, 04:25 AM   #6
Arturin's Avatar
Thats were I´m getting them from
Old 04-04-2010, 05:22 PM   #7
355
355's Avatar
Ferrari Life Posts: 64
Its the dimmer switch for all of your gauge lights.
355 is offline   Reply With Quote
Old 04-04-2010, 09:44 PM   #8
Pete04222's Avatar
Ferrari Life Posts: 5,405
thanks
29 and 23 are shields that prevent oil from contaminating the belts should the camshaft seals leak. They need to be installed BEFORE the belts. You can leave them off with no problems. Just get them and install them next time you change the belts. If your camshaft seals are leaking then you will need to change the seals and the belts and make sure you put these plates in. If the camshafts are not leaking you are fine leaving these plates out.
As for the 3 bolt vs. 5 bolt, the cover is just a machinery guard and doesn't affect the operation or performance of the engine, it just keeps rocks and fingers and squirrels out of the belts. Given the option I'd go with the 5 bolt. With the 3 bolt if one loosens there is only 2 holding it on. There is no problem with the 3 bolt but if that's the one you get consider just a drop of blue Loctite on the bolt threads.
Capt. Pete
Pete04222 is offline   Reply With Quote
Ferrari Life » Ferrari Forum » Ferrari Owners » Pre '99 V8s: GT4, 308, 328, 348, F355 » Buying missing parts, need advice
