308 "points to electronic ignition"
Old 02-14-2010, 07:35 AM   #1
Default 308 "points to electronic ignition"
Hello Ferrari Friends:
Has anyone had any experience using the Petronix Ignitor II "points to electronic iginition conversion units" that are made for the 308 Marelli distributors?
Any feedback would be great!
swflorida789 is offline   Reply With Quote
Old 02-14-2010, 08:20 AM   #2
Ferrari Life Posts: 90
I have that unit on my 1978 308 GTS. Came to me that way. I plan to change to change the pick ups under the distributor as when it was installed the mechanic put both under the rearmost distributor as it was easier. Makes sense to me to have one on each bank as intended. Probably not a huge deal.Other than that, it's been a trouble free ignition. I'm sure that there are better performance units that use a computer and different advance curves but this seems ok as I'm not really pushing mine for racing etc. Bill
bill ward is online now   Reply With Quote
Old 02-14-2010, 08:28 AM   #3
Hi Bill:
Thanks for the fast reply!
So you have the Twin Distributor setup? And, there are two Ignitor II units in the rear Marelli distributor? I had no idea that there was enough room for two units in one distributor or if that was even possible?
And, yes your right there are many better Elec. Ignition Systems out there, but I too am not racing my gt4 and I'm looking just to improve the iginition system without changing the stock appearance.
Thanks again for your reply.
Steve
Last edited by swflorida789; 02-14-2010 at 09:46 AM. Reason: Re-read you response and then the light bulb lite up!
Old 02-14-2010, 08:36 AM   #4
Yes- Twin Distributor. Supposed to be one pickup under each cap but for now both under rear cap. They (pertronics) have a pretty helpful web site that I found by doing search for pertronics ignition systems. Bill
Old 02-14-2010, 02:21 PM   #5
Pete04222's Avatar
Ferrari Life Posts: 5,405
I did the swap to electronic on my '79 about 5 or 6 years back. I used two of the Crane Cams Fireball 3000 ignitions. Did it myself, was very careful and the car fired right up when I was through. Took it to a shop to have the carbs sync'ed and haven't had any issues since.
I had a thread about the swap, I'll see if I can't find it.
Capt. Pete
Pete04222 is offline   Reply With Quote
Old 02-14-2010, 02:26 PM   #6
Pete04222's Avatar
Found the old thread without too much trouble:
308 ignition upgrades. Magoo? Peter?
Capt. Pete
Ferrari Life » Ferrari Forum » Ferrari Owners » Pre '99 V8s: GT4, 308, 328, 348, F355 » 308 "points to electronic ignition"
