Ferrari Life » Ferrari Forum » Ferrari Owners » Pre '69: 212, 250, 275, 330, 365 ::
How and when to approach "D"s A/C Compressor restoration?
Old 04-07-2012, 10:15 AM   #21
Neopolitano's Avatar
Ferrari Life Posts: 140
212- ......................................... One of my friends upgraded his 330 GTC because he lives in Florida, and it works much, much better now. In Switzerland that may be overkill unless you frequently take her to Spain or Italy.
I am the one that had the GTC a/c upgrades done. There is one very easy change you can make that no one will see. That is to replace the interior blower motor with an MB 97 E-class motor. My tech says it is a slip-out slip-in swap. It significantly increases the volume of air you are pushing. With the Daytona having the top dash vents this makes a big difference in how much air reaches you when driving. My shop did the first blower motor swap on a friends Daytona.
Steve
______________
Current: SA, 330 GTC, Dino, BB, QP
Past: GTC, BB, QM, C/4, 355, 360, 550, 575, C/4
Neopolitano is offline   Reply With Quote
Old 04-07-2012, 10:34 AM   #22
Ferrari Life Posts: 7,474
Thanks, I remembered you had done several things to the A/C system to increase efficiency without changing the look. Nobody could see that fan change without dismantling the car and even then nobody would notice without a parts catalog in hand. Probably not even then.
Old 04-08-2012, 09:36 AM   #23
212Export's Avatar
Ferrari Life Posts: 2,976
Many thanks. Will pass that precious info to my mechanic after Fled.
Old 04-19-2012, 08:42 PM   #24
SCM246's Avatar
Ferrari Life Posts: 417
Originally Posted by Boxer View Post
Ferrari Life Epic Drive - which this year will be 5 days across Scotland.
Thank you, sounds fun
Excellent!
Classic condensors sell this upgrade for the Dino, pushing the width to the far edge while still being able to fit. Not sure if the Daytona has this same old inefficient condensor fit?
Second photo is the the TCCI compressor I installed in the Bora, an exact fit on all 3 axis (BTW, I recall Maserati used eight cap bolts to mount it).
SCM246 is offline   Reply With Quote
Old 06-28-2012, 03:38 AM   #25
212Export's Avatar
Update on the AC compressor: I gave "D" to the same auto electrician who fixed my distributor problem. Brought it Monday. After 2 hours he called me to tell that a small gasket at the point of the main compressor axle of the AC compressor had been broken. He ordered in in the Netherlands, got it within 2 days andfixed it all together. So I have still the original AC Compressor aboard, it works very well and cooooooools fine. Picked it up today.
Old 06-29-2012, 11:46 AM   #26
I love a happy ending.
Old 07-07-2012, 05:44 PM   #27
SCM246's Avatar
Anyone got a part number?
Did a quick lookup and found
Your Parts Search Returned 2 Part(s)
2108206842
Behr OEM
Blower Motor; Late Version Blower Motor Assembly with Male Connector
If replacing original 2108205242 blower assembly, also need 2108211551 blower regulator and 2108352740 mounting plate. 1 per car.
$300.00
$231.56
Old 07-07-2012, 11:58 PM   #28
JazzyO's Avatar
Ferrari Life Posts: 5,161
Great stuff, 212. When are you and D going on an epic adventure again?
Onno
Future: No idea
Past: 365BB x 2,
330GTC
JazzyO is offline   Reply With Quote
Old 07-24-2012, 03:06 AM   #29
212Export's Avatar
Onno
Onno, went to Portofino and back and then to Germany. Another 2000+km's flawless. Plan for a 3000 km drive in September.
Old 02-05-2013, 10:55 AM   #30
Question, can the compressor be removed without removing the radiator?
jimmyr is offline   Reply With Quote
Ferrari Life » Ferrari Forum » Ferrari Owners » Pre '69: 212, 250, 275, 330, 365 » How and when to approach "D"s A/C Compressor restoration?
