Ferrari Life » Ferrari Forum » Ferrari Owners » Pre '69: 212, 250, 275, 330, 365 ::
275 GTB Valve Screw Excessive Wear
Old 11-19-2010, 05:58 PM   #1
Jimmy Chen Shiba DDS's Avatar
Ferrari Life Posts: 3,550
Name: Jimmy Chen Shiba
Default 275 GTB Valve Screw Excessive Wear
I have mentioned this problem under the "Ferrari Owners' 275 Section in the Running report of #08191. While I had the car in shop to repair hairline crack in the radiator, I was concerned about this "sound" of the engine and we decided to open the cover to see what was going on. Discovered were several excessviely worn out valve lash adjuster screws.
My question here is to ask for opinions as to what could have caused such wears in some of the screws ? The car underwent total overhaul several years back and is still under 3,000km since. Would appreciate any insights for my own learning curve. Thanx in advance.
Meanwhile, the shop is fabricating new screws for replacements. w/ smiles Jimmy
Old 11-20-2010, 12:02 AM   #2
Ferrari Life Posts: 12,792
Are you sure the screws were replaced when they did the overhaul?
Boxer
Old 11-20-2010, 12:08 AM   #3
I am quite sure, Boxer. (Altho, this was done under the ownership of the previous owner). My understanding of complete overhaul is to check everything. They even replaced the no problem cams with a whole new set at the time (don't know why because the original ones look fine; I have them with me). w/ smiles Jimmy
Old 11-20-2010, 02:53 AM   #4
No idea why they would have worn so quickly then.
Boxer
Old 11-20-2010, 03:43 AM   #5
Ferrari Life Posts: 2,408
The key might be in the statement:
"Meanwhile, the shop is fabricating new screws for replacements"
If the parts are not available form ferrari and were fabbed up then sending them out to have the alloy and hardness confirmed would be the only way to know if they ever met OEM spec of not. There are whole lot of alloys and heast treating processes out there, getting the dimensions correct is only 1 piece of the puzzle ......
Old 11-20-2010, 05:03 AM   #6
Jimmy, the adjuster screws are made to wear. The valve stems are hardened so they don't mushroom, the adjusters are softer and made to be adjusted. Depending on the supplier will determine the quality of the parts. Contact Geoff Ohland at Partsource, 207-236-9791 he has the correct adjusters. Replace them all while you have the valve cover off. By the way Geoff used to work for Luigi Chinetti and is the best for vintage Ferrari parts.
12340 is online now   Reply With Quote
Old 11-20-2010, 06:08 AM   #7
Thanx for the comments, guys. Prior to my purchase last year, the previous owner had the car shipped to Italy from Japan (can you believe that ?!?!) for thorough overhaul, spending a bundle (got invoices). Don't bother asking how much, too much. Maybe that is when something went wrong. Since this resto, the km. meter was reset to zero and has clocked under 3,000km so far. As you can see, the wear of the screws crazy !
Anyway, I have contacted Mr. Roelof's shop who supply their own modified kit which should take care of this problem. I would try other suggestions too. In the meantime, new race quality screws are being ordered to be fabricated by a race shop. See how this works out. w/ smiles Jimmy
Old 11-20-2010, 06:10 AM   #8
Thanx for your lead, 12340. I shall do so when I am back in LA next week. Thanx again. w/ smiles Jimmy
Old 11-22-2010, 11:20 AM   #9
hhh
Piet Roelofs has the best modified parts for that. I have raced 275GTB's with them and they work well.
Before these were available I remember replacing some of them on a GTB/C 4 times in 3 days.............not funny.
hhh is offline   Reply With Quote
Old 11-22-2010, 11:47 AM   #10
Thanx for your comment, hhh. Seems like Mr. Roelof's product is a must have. Did get a reply from his shop and the kit was quoted as 1575 Euro. w/ smiles Jimmy
Old 11-22-2010, 02:18 PM   #11
Ferrari Life Posts: 477
American cars have also suffered from ruined camshafts and solid lifters due to the protective additives being removed from modern oils.
You may want to pay close attention to what oil is being used in the car and whether or not additives are being used also to help avoid similar issues.
Exotic Car Specialties
201 Davis Dr. Suite L
Sterling, VA 20164
703.421.5356
Old 11-22-2010, 11:26 PM   #12
Thanx, Josh. Would check this out too, as suggested. Thank You. w/ smiles Jimmy
Old 11-23-2010, 05:24 AM   #13
Ferrari Life Posts: 166
A long time back I had some VW heads rebuilt. Short story was I had wear "opposite" of yours, the valve stems were going away within just a few 100 miles. The stems had been ground down past the hard end into the softer stem, and the adjusters hammered them flat in no time.
The valve stem end and the adjuster end are very, very hard metal, and should wear about equally against each other. In fact they really shouldn't show signs of wear before any other major parts have completely worn out several times.
So while oil, specifically the removal of zinc additives, have shown increased wear, I think you need to look more critically at the part itself as Mark suggested. If it were an oil issue that caused these parts to wear so rapidly, I think you would have some other issues.
I would locate a full set of OEM adjusters and replace all of them.
Artvonne is offline   Reply With Quote
Old 11-25-2010, 09:33 AM   #14
JazzyO's Avatar
Ferrari Life Posts: 4,289
Welcome here, hhh, nice to see such experienced owners chipping in.
Onno
JazzyO is offline   Reply With Quote
Old 11-25-2010, 09:56 AM   #15
212Export's Avatar
Ferrari Life Posts: 2,288
Was that your personal GTB/C ? Was it a first series (I guess) or a 2nd series GTB/C ?
Ferrari Life » Ferrari Forum » Ferrari Owners » Pre '69: 212, 250, 275, 330, 365 » 275 GTB Valve Screw Excessive Wear
