F430 F1 pump motor NEW model - Ferrari Life
 3Likes
post #1 of 74 Old 08-10-2015, 06:09 PM Thread Starter
Ferrari Life Posts: 109
This is a new, more powerful electric motor with a specialized F1 pump adapter for manual and F1 equipped F430, F430 Challenge starting from 2006, Ferrrari Scuderia, 16M, 599GTB & GTO. It fits Magneti Marelli hydraulic gear pump head in Ferrari part # 214267, 248083, 248087. The adapter has exactly the same mounting holes as the original part (the new mounting screws are included into the kit). Electric connectors are directly fitting the F1 TCU harness: the negative, ground wire (black) should be attached to the front of the pump subframe, while the positive wire (red) connects with the harness wire connector.
Usually, the F1 system fails due to the old electric motor. The pump head itself fails very rarely, mainly if some debris, like metal shavings, gets inside with hydraulic oil. As I have described in my previous posts, the electric motor can be changed without disconnecting hydraulic lines.
This F1 pump electric motor is now available on eBay for much less than the old model:
Electric Motor for F1 Pump Ferrari Maserati part 214267, 248083, 248087
Also, it is available with the pump head:
F1 Pump Ferrari Maserati Part 214267 248083 248087 | eBay
Also, with another small adapter part this motor is the same as (Ferrari part #213264, #247223); the motor or the whole pump can be directly installed in Ferrari 575M, F1 Modena and Spider, 612 Scaglietti, Challenge Stradale, Enzo, and F430 manual 6-speed - before assembly #61702; F430 F1 shift system - before assembly #61589.
Electric Motor for F1 Pump Ferrari 360 430 Maserati Lamborghini E Gear | eBay
F1 Pump Ferrari 360 430 Maserati 213264 247223 Lamborghini E Gear 0863983 | eBay
jgelovani is offline
post #2 of 74 Old 08-13-2015, 08:30 PM Thread Starter
Heat Sink 360* for NEW F1 pump and electric motor.
This optional 360* heat sink covers the whole body of this NEW F1 pump electric motor and efficiently reduces its operating temperature. As the result of lower operating temperature, this NEW F1 pump draws less current (lower Amp), as compared to old F1 pump models.
Motor: Electric Motor for F1 Pump Ferrari Maserati Part 214267 248083 248087 | eBay
Pump: F1 Pump Ferrari Maserati Part 214267 248083 248087 | eBay
post #3 of 74 Old 08-16-2015, 09:08 PM Thread Starter
Here is a comparison of specifications of electric motors :
OLD MOTOR : -------------------------------------------------------------------------------
Parameter Voltage (V) Torque (Nm) RPM med Current (A)
Free Load 12 0 4100 ≤ 2.5
Normal Load 12 0.20 3880 ≤ 11.3
Max Efficiency 12 0.35 3380 ≤ 17.3
NEW MOTOR :------------------------------------------------------------------------
Free Load 12 0 5310 2.7
Normal Load 12 0.45 4320 27.0
Max Efficiency 12 0.32 4614 19.8
Max Power 12 1.21 2655 67.9
Stall 12 2.42 0 133.0
The new motor has double the torque / power and higher RPM.
post #4 of 74 Old 08-16-2015, 11:32 PM
Italian Lover's Avatar
Ferrari Life Posts: 6,679
Jg, appreciate your F1 pump informations as my 16M had its F1 pump replaced few weeks back due to unintentional stalling and subsequent restart difficulty. Was diagnosed as F1 pump failure which was told also that this is a common issue with 430s...
From your posts, I take it that the new ones are more reliable (?) and fitting is a nonissue ? Is Ebay the only way to acquire the items ? Maybe I ought to get a set for the next time around. Would this work for 575 SA also ? Thanx in advance.
w/ smiles
Jimmy
Italian Lover
Italian Lover is online now
post #5 of 74 Old 08-17-2015, 02:31 AM
550_Maranello's Avatar
Ferrari Life Posts: 1,233
w/ smiles
Jimmy
Hi Jimmy,
on your 16M you has already had to replace the F1 pump ? But your car has very few km ...and is like new ... why this, your 16M it was stop in garage for long time before you bought?
Now the F1 gearbox works in correct way?
Fabio
550_Maranello is offline
post #6 of 74 Old 08-17-2015, 02:32 AM
Hi Jg,
interesting and nice information & work!
Best Regards
Fabio
Fabio
post #7 of 74 Old 08-17-2015, 03:05 AM
Hi Jimmy,
Fabio, I still have not received the car back yet due to holidays here, but the problem seemed to be the F1 pump.
I agree that the mileage was quite low when I bought her, less than 9,000 km. She ran perfectly since but few weeks back, she began to stall for no reasons and restarting was not immediate either. My friend later said that the gears did not drop properly too. The problem seemed to be the F1 pump failure to maintain adequate pressure to function properly. My friend also discovered through his network friends that 430 models are known well for the F1 pump failures too.
Probably ( I am assuming) that one of the reasons was the lack regular usage, like you said.
I would let you know how she is as soon as I get her back in the next couple of days.
w/ smiles
Jimmy
Italian Lover
post #8 of 74 Old 08-17-2015, 04:57 AM
w/ smiles
Jimmy
Jimmy,
yes i think a regular use of car will do the better state of function.
I come back to work today after 10 days of holiday, i went with my wife and little girl in mountain "Madonna Di Campiglio" at 1500 meters over sea level, there was a very nice sun days ... never humidity, never mosquitoes and 25 C.
Now in Cesena, near the Adriatic sea, 30 C and lot of mosquitoes..
How is the weather in Japan now?
Fabio
post #9 of 74 Old 08-17-2015, 09:02 AM
Fabio, for someone who has yet to visit Italy, everything sounds perfect.
Weather here has not been pleasant at all. After the long rainy season of five weeks in June/July the summer has been extreme heat in the mid 30 C and high 30s inland. Heat, humidity and bugs too. Forgot to mention the typhoons which caused havocs.
Right at this moment, there are two typhoons heading this way and one may be coming our direction next week.
w/ smiles
Jimmy
Italian Lover
post #10 of 74 Old 08-17-2015, 05:13 PM Thread Starter
w/ smiles
Jimmy
Hello,
Thank you for reviewing my post and raising important questions.
I am adding more data comparing the motors from Ferrari : 1) part 213264; 2) part 214267 (aka, 248083 and 248087); and 3) new electric motor shown in this post:
# 213264-----Voltage (V)----Torque (Nm)--Torque (Oz-In)-- RPM med--Current (A)
Free Load-------12----------------0------------------0---------------- 4100------------≤ 2.5
Normal Load----12-------------- 0.2 --------------28.3--------------3880------------≤ 11.3
Max Efficiency--12--------------0.35--------------49.6--------------3380------------≤ 17.3
#214267-----Voltage (V)----Torque (Nm) --Torque (Oz-In)-- RPM med--Current (A)
Free Load-------12--------------0 ----------------- 0.0----------------3700--------------7.0
Normal Load----12--------------0.15--------------21.2---------------3300-------------11.5
Max Efficiency--12--------------0.35--------------49.6---------------2800-------------18.0
Max Power-------12--------------0.5----------------70.8---------------2500-------------22.5
New Motor-----Voltage (V)----Torque (Nm)--Torque (Oz-In)-- RPM med--Current (A))
Free Load-------12--------------0 ------------------0.0---------------5310--------------2.7
Normal Load---12--------------0.45---------------64.0--------------4320--------------27.0
Max Efficiency-12--------------0.32---------------45.0--------------4614-------------19.8
Max Power-----12--------------1.21--------------171.7-------------2655--------------67.9
Stall---------------12--------------2.42--------------343.4--------------0----------------133.0
This new motor is equipped with universal adapter(s) that will fit any Ferrari, Maserati, and Lamborghini cars with F1 electro-hydraulic gear shift system from Magneti Marelli (including the 575M).
NOTE ! Because this new electric motor model (black body) draws more current, it should be used with at least a 50Amp fuse and F1 relay, but I recommend to use a 70Amp relay (in combination with a 50Amp fuse, which will blow before the relay can be damaged). This is the same reason to why a 50Amp fuse and relay are used with 214267 (aka, 248083 and 248087) pump motor.
Here is the eBay link to a 70Amp relay:
F1 Pump Relay 12V 70A 4 Prong Ferrari Maserati 233100 Upgrade Aftermarket | eBay
post #11 of 74 Old 08-17-2015, 06:38 PM Thread Starter
New F1 Pump Repair Kit for Ferrari part 213264
And here is the new aftermarket F1 pump repair kit for Ferrari part #213264 for thosse who prefer a similar hydraulic pump head coupling and mounting adapter.
Electric motor: Electric Motor for F1 Pump Ferrari 360 430 Maserati Lamborghini E Gear | eBay
Whole new pump: F1 Pump Ferrari 360 430 Maserati 213264 247223 Lamborghini 0863983 Repair Kit | eBay
post #12 of 74 Old 08-17-2015, 09:46 PM
Jg, appreciate your detailed follow ups.
To be honest, the specs beyond my head so I would discuss this with my friend to explore the possibilities.
Much appreciated.
w/ smiles
Jimmy
Italian Lover
post #13 of 74 Old 08-18-2015, 02:19 AM
Ferrari Life Posts: 2,106
JG, do you happen to have the pressure/flow ratings of this pump?
It may be interesting to use for another application. Could you PM me your email address so we can discuss further?
post #14 of 74 Old 08-18-2015, 08:50 PM Thread Starter
The pump head is the same as in the original Magneti Marelli F1 pump model so the pressure/flow ratings are the same (assuming that torque/RPM and pressure/flow relationships remain linear over the normal operation range).
Here some of the parameters you were asking about for Marelli F1 pump head:
Displacement (cm3/rev) = 0,25
Flow at 1500 rpm = 0,3 L/min
Flow at max rpm = 0,8 L/min
Pressure nominal (bar) = 200
Max rpm = 3500
I have been using this type of motor together with pump heads from Marzocchi that have larger output (i.e., 0.5 ml/rev) in R&D for racing applications and found it performing very well (as it has double the torque at the same RPM, although drawing almost double the current).
Parameters of a larger pump head I am using for racing applications (to maintain 65-90 bar operating pressures faster by shorter pumping cycles, required for more frequent shifting during racing) are shown below:
Displacement (cm3/rev) = 0,5
Flow at 1500 rpm = 0,7 L/min
Flow at max rpm = 1.6 L/min
Max rpm = 3500
If you have any questions, let me know.
Kind regards,
Juri.
post #15 of 74 Old 08-19-2015, 02:41 AM
Thanks Juri, one of these may work very well for the application. I've sent you an email.
post #16 of 74 Old 08-19-2015, 08:17 AM
Ferrari Life Posts: 6,174
I have no business being in this thread, and have never owned a F1 system.
Having said that I must ask the question that ponders me IF I were in this market [and remember this is nothing personal or even a detraction, but something I would be asking]
LEGAL DISCLAMER: The seller hereby expressly disclaims all warranties, either expressed or implied warranty or merchant ability of fitness for a purpose, and neither assumes nor authorizes any other person to assume for it any liability in connection with the sale of this merchandise. Neither seller nor manufacturer shall be liable for any loss, injury or damage, direct or consequential, arising out of the use of, or the inability of product. By purchasing and using this product, the purchaser and user of this product shall assume all risk and liability whatsoever in connection thereof.
I have had, 'minor' aftermarket items that are much better than OEM in terms of OES etc.
but
On a warrantied car, I wonder what a purchaser should be considering in this major component based on non-OEM part?
can you help -- off/on -- the record.
THEN, based on the above, and perhaps you already have stated these items: What is the record on this item from other customers?
thanks
rik
post #17 of 74 Old 08-19-2015, 06:34 PM Thread Starter
but
thanks
rik
Hello Rik,
I understand that some people are more skeptical and/or litigeous than others... That is why I use this standard legal disclaimer (as other aftermarket manufacturers for any other part).
You are asking for the record on this items from other customers, but please consider that this product has been just announced on this forum and other than my own R&D, I have only few of these pumps installed so far and would like to have more feedback from those who will consider installing these pumps in their cars.
Last week, one of these new F1 pumps for 430F1 (equipped with a 360* heat sink) was installed in a track car in Philippines. So far, the racing team tech is satisfied with it's performance and continues monitoring.
I hope that this answers your questions.
Kind regards,
Juri.
post #18 of 74 Old 08-20-2015, 09:17 AM
Hello Rik,
Kind regards,
Juri.
I look fwd to the continued performance reviews and truly hope it performs well. I suspect as I've known others [Dave Helms for example on his hoses] or Hill engr. to over engineer but add huge value to us that need real solutions.
Side note: Ferrari has become to me a company that overcharges for what should be a slam dunk on engineering and/or implementation, but sadly ALWAYS falls short on both which makes for a great fail IMO.
glad you are in this game.
post #19 of 74 Old 08-20-2015, 04:27 PM Thread Starter
Hello,
I tend to agree with you about overpriced and sub-optimally engineered critical components and systems installed in Ferraris, because those have been subcontracted to other companies. F1 sequential gear shift system by Hydraulik Rink -> Magneti Marelli -> Ferrari is but one example...
Regards,
Juri.
post #20 of 74 Old 10-15-2015, 06:30 PM
So, based on what I see on eBay, for a 2005 430 F1 is I want to change just the pump motor (don't want to drain the hydraulic fluid), I would need the following?
one of these : Electric Motor FOR F1 Pump Ferrari 360 430 Maserati Lamborghini E Gear | eBay
Two of these: F1 Pump Relay 12V 70A 4 Prong Ferrari Maserati 233100 Upgrade Aftermarket | eBay
and 2 - 50 amp fuses?
If ones pump is still working, will changing to the higher spec pump possibly improve shifting?
martiy1971 is offline
