360 What oil to top off with? Can't find Shell anywhere
Old 04-14-2012, 07:16 AM   #1
waterboy222's Avatar
Ferrari Life Posts: 42
Default What oil to top off with? Can't find Shell anywhere
Got the car home from an 11 hour drive from Chicago yesterday! That was a great way to break her in. But after washing it and checking everything, it seems she's a little low on oil. Ive looked around and can't find anybody local that stocks Shell Helix oil. What can I top it off with that won't hurt it and will mix ok?
waterboy222 is offline   Reply With Quote
Old 04-14-2012, 07:19 AM   #2
Ferrari Life Posts: 5,909
you can mix oil mineral and synthetic and it won't matter in today's ratings as long as you keep the same designated weight.
Old 04-14-2012, 07:29 AM   #3
Ferrari Life Posts: 7,464
Quaker State Q is the Shell Ultra Helix rebadged for the US. Shell owns QS and Pennzoil.
Old 04-14-2012, 07:47 AM   #4
That's great information, thanks' I'll see what I can find. What weight should
I use?
Old 04-14-2012, 08:00 AM   #5
Ferrari Life Posts: 32
Owner's manual says 5W-40 or 0W-40.
JeffWilliams is offline   Reply With Quote
Old 04-14-2012, 09:43 AM   #6
The Q doesn't say it's synthetic on the bottle. They have Q durability, q horsepower, defy, enhanced durability, advanced durability. Which one is it? The only one that says synthetic is the horsepower 5w20
Old 04-14-2012, 09:44 AM   #7
Ok to use Mobil 1 0w-40? It's all I can find in my small town.
Old 04-14-2012, 09:50 AM   #8
Ferrari Life Posts: 1,148
Make absolutely certain it really is low on oil. Very common mistake to over fill and that will be a bad day. Follow the instructions in the owners manual to the letter.
Between low and full is fine. There is no need for it to be all the way to full.
By federal law all motor vehicle motor oil must be compatible.
Brian is online now   Reply With Quote
Old 04-14-2012, 10:26 AM   #9
It barely shows any oil on the tip of the stick.
Old 04-14-2012, 10:53 AM   #10
are you sure you are testing the dipstick correctly after a full warm up and run . common mistake on a dry sump is testing the dipstick when you haven't had the temperatures of the full temps, which will result in a very low reading which you maybe seeing. that is internet speak. but basically is what the manual says .
Old 04-15-2012, 08:01 AM   #11
That's exactly what I was doing. I didn't realize you had to have it running and warm to check the level. With a cold motor, it was barely registering on the dipstick.
Old 04-15-2012, 05:35 PM   #12
Ferrari Life Posts: 30
I top my 430 off with Mobil 1 0W-40.
Rob
rj45 is offline   Reply With Quote
Old 04-16-2012, 08:36 AM   #13
Read and follow the owners manual.
Ferrari Life » Ferrari Forum » Ferrari Owners » Modern V8s: 360, F430 » 360 What oil to top off with? Can't find Shell anywhere
