360 Problems with the remote/alarm system
Old 01-18-2012, 08:37 PM   #1
Ferrari Life Posts: 5
Default Problems with the remote/alarm system
I have an '03 360 spider. For the last 2 days I have not been able to start the car. The remote fails to de-activate the alarm system to allow me to start the engine. I've tried both of my remotes and also changed the battery in the remote, but no luck.
aaryana is offline   Reply With Quote
Old 01-19-2012, 03:47 AM   #2
Ferrari Life Posts: 28
Did you look in the manual for instructions? The F430 had something to do with activation codes.
2003 360 Spider Manual (US):
http://www.ferraridatabase.com/The_D...02003%20US.pdf
Mo T is online now   Reply With Quote
Old 01-21-2012, 09:45 AM   #3
Ferrari Life Posts: 13
If you have your PIN number, you can go through the no-remote starting procedure. Do you have your PIN number? - Jeff
JeffWilliams is offline   Reply With Quote
Old 01-21-2012, 09:54 AM   #4
Arash- Here is a document showing how to start the car with the Alarm PIN and key alone. On the remotes, you may need to squeeze the contacts together, and I hold the contacts on the battery with one hand and spin the battery with the other to ensure good contact. I also apply a drop of battery terminal treatment to the contacts with a toothpick to prevent corrosion.
Will the remotes lock and unlock the doors?
File Type: doc Programming Alarm ECUs with New Fobs.doc (2.04 MB, 27 views)
Old 01-22-2012, 08:11 PM   #5
Guys, thanks for your quick and helpful replies.
FYI -- It was actually nothing short of an embarrassing (make that stupid) mistake. I was charging the battery at the time using my trickle charger. I quickly realized that was the problem -- that is the alarm does not allow you to start the engine when the hood is open.
Unfortunately, I don't have the PIN number since I'm not the original owner. Anyone know if you can get the PIN thru Ferrari?
Old 01-22-2012, 08:34 PM   #6
Arash- Affirmative. Last time I heard, they were charging about $500 for your original PIN.
Ferrari Life » Ferrari Forum » Ferrari Owners » Modern V8s: 360, F430 » 360 Problems with the remote/alarm system
