Ferrari Life Posts: 8
anyone know what parts do i need to change and the parts number? thank you |
Roy- They are all listed here and it depends on whether you have F1 or not. Without F1 you need a clutch assembly and throwout (thrust) bearing. With F1 you need a clutch assembly (same as the non-F1 cars), a different throw-out bearing, and a clutch position sensor. Plus seals for the T/O (thrust) bearing unless you buy a Hill Engineering T/O bearing with seals already installed. The bottom url tells you which seals you would need if you go with an OEM bearing. Anything else, anybody? You can find all those listed here on Ricambi's site. Let us know if you need us to break them our exactly. Ferrari Parts, Ferrari Accessories, and Ferrari Performance Products - Ricambi America, Inc. Ferrari Parts, Ferrari Accessories, and Ferrari Performance Products - Ricambi America, Inc. Ferrari Parts : CRB430F1-MS : CRB430F1-MS F430 Clutch Release Bearing F1 (234943 Taz Terry Phillips Present: 575M 135171 Past: Dino 246 GT 02984, 365 GTB/4 14009, 308 GTS 25125 Every day I look around, and if nobody is shooting at me, it is a pretty good day. |
Ferrari Life Posts: 779
And to be really complete, here's the link for the manual HI throw-out bearing with all seals pre-fitted: Ferrari Parts : CRB430MS : CRB430MS 6-speed Clutch Release Bearing (234943) |
hi sorry i forgot to mention my car is f1 transmission 2006 spyder 12000 km, do i need flywheel? |
| Owner Elite Member Join Date: Aug 2011 Location: Boulder, CO
Ferrari Life Posts: 90
Roy- You sure you need a clutch? 12,000 kms is kind of quick wear for an F430 clutch. You should be able to just resurface your flywheel if you do need one. What symptoms are you seeing or did an SD3 tell you it was worn out? Taz Terry Phillips Present: 575M 135171 Past: Dino 246 GT 02984, 365 GTB/4 14009, 308 GTS 25125 Every day I look around, and if nobody is shooting at me, it is a pretty good day. |
| the dealer did an sd 3 and show the clutch 33 percent left, i thought its because indonesia traffic is so bad, traffic jam every where
